嗨,
我在使用BRAM时出现溢出问题(110%) 有没有办法使用tcl命令,我说某些单元格,实现它们作为分布式RAM而不是BRAM? 修改一些属性或什么? 谢谢, 以上来自于谷歌翻译 以下为原文 Hi, I'm having a problem with overflow in the use of BRAM (110%) Is there is a way using tcl commands , where I say for certain cells, implement them as distributed RAM istead of BRAM ? Modifying some property or something? Thanks, |
4个回答
你好@ pumaju1808
打开详细设计并选择所需的RAM实例并使用以下tcl命令: set_property RAM_STYLE已分发[get_cells] 要么 在详细设计中选择RAM实例后,您可以将RAM_STYLE属性更改为分布式。 谢谢, 维奈 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Hi @pumaju1808 Open elaborated design and select the required RAM instances and use the following tcl command: set_property RAM_STYLE distributed [get_cells Or After selecting the RAM instances in elaborated design, you can change the RAM_STYLE property to distributed. Thanks, Vinay -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution.View solution in original post |
你好@ pumaju1808
打开详细设计并选择所需的RAM实例并使用以下tcl命令: set_property RAM_STYLE已分发[get_cells] 要么 在详细设计中选择RAM实例后,您可以将RAM_STYLE属性更改为分布式。 谢谢, 维奈 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi @pumaju1808 Open elaborated design and select the required RAM instances and use the following tcl command: set_property RAM_STYLE distributed [get_cells Or After selecting the RAM instances in elaborated design, you can change the RAM_STYLE property to distributed. Thanks, Vinay -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
我在哪里可以获得xilinx文档中的所有这些属性和对象类型?
谢谢, 以上来自于谷歌翻译 以下为原文 Where can I get all these properties and type of objects in xilinx documentation? Thanks, |
pumaju1808写道:
我在哪里可以获得xilinx文档中的所有这些属性和对象类型? 谢谢, UG912 UG901 使用DocNav或谷歌查找。 ***我们中的许多人都是FPGA爱好者,而不是Xilinx员工。 如果您获得帮助并给予荣誉(明星),您将来可能会继续获得帮助。 如果您有解决方案,请将其标记为解决方案。*** 以上来自于谷歌翻译 以下为原文 pumaju1808 wrote:UG912 UG901 Use DocNav or google to find. ***Many of us who help you are just FPGA enthusiasts, and not Xilinx employees. If you receive help, and give kudos (star), you're likely to continue receiving help in the future. If you get a solution, please mark it as a solution.*** |
2501 浏览 7 评论
2871 浏览 4 评论
2330 浏览 9 评论
3424 浏览 0 评论
2512 浏览 15 评论
2466浏览 1评论
662浏览 1评论
524浏览 1评论
802浏览 0评论
GMT+8, 2025-2-25 09:59 , Processed in 1.179880 second(s), Total 48, Slave 43 queries .
