大家好,
我正在开发一些CAN通信项目,它允许我们控制从一个其他节点连接到一个节点的一些外部设备。 由于CAn总线是广播网络,因此节点发送的消息将由总线上的每个其他CAn节点接收。 我的要求是我需要为节点实现过滤机制,以便节点只对那些接收到的消息起作用 为其配置(使用一些GUI实用程序)。所以我需要在我的代码中实现这个过滤机制。我正在使用STM8SAF52Ax mcu IAR嵌入式工作台作为开发环境。 我怎么能实现can消息的过滤过程。我也做了网络搜索和阅读许多其他教程,但我仍然无法弄清楚要做什么。有使用CAN过滤器Id和过滤器掩码,但我无法确定要在这些值中加载什么值以及如何计算这些值。 请提供一些教程或任何解释或一些示例。 谢谢 阿米特库马尔 Email-amitkrv22@outlook.com #becan#can-message-filtering 以上来自于谷歌翻译 以下为原文 Hi all, I am working on some CAN communication project which allows us to control some external device attached to one node from some other node. Since the CAn bus is a broadcast network and hence a message sent by a node will be received by every other CAn node on the bus. My requirement is that i need to implement a filteration mechanism for the nodes so that a node will only act upon those received messages for which it is configured(using some GUI utility). So i need to implement this filter mechanism in my code.I am using STM8SAF52Ax mcu with IAR embedded workbench as developement enviornment. How could i implement this filter process of can messages.I also did web search and read many other tutorials but still i am unable to figure out what to be done. There are use of CAN filter Id and filter mask but i am unable to decide what value to be loaded in these and how to calculate these values. Please suggest some tutorials or any explanations or some examples. Thanks Amit Kumar Email-amitkrv22@outlook.com #becan #can-message-filtering |
我希望它类似于STM32实现。即顶部11位是ID,假设传输顺序为位,高位优先。
您可以查看这些以及您的参考资料。 [死链接/public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/Flat.aspx?RootFolder=/public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/STM32%20CAN%20acceptance%20mask&FolderCTID=0x01200200770978C69A1141439FE559EB459D7580009C4E14902C3CDE46A77F0FFD06506F5B¤tviews=79]https:/ /my.st.com/public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/Flat.aspx?RootFolder=/public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/STM32%20CAN%20acceptance%20mask&FolderCTID=0x01200200770978C69A1141439FE559EB459D7580009C4E14902C3CDE46A77F0FFD06506F5B¤tviews=79 [DEAD LINK /public/STe2ecommunities/mcu/Lists/STM32Java/Flat.aspx?RootFolder=/public/STe2ecommunities/mcu/Lists/STM32Java/STM32F4%20-%20can%20bus%20Id%20filters%20configuration&FolderCTID=0x01200200770978C69A1141439FE559EB459D758000F9A0E3A95BA69146A17C2E80209ADC21& currentviews = 135] https://my.st.com/public/STe2ecommunities/mcu/Lists/STM32Java/Flat.aspx?RootFolder=%2Fpublic%2FSTe2ecommunities%2Fmcu%2FLists%2FSTM32Java%2FSTM32F4%20%2D%20can%20bus %20Id%20filters%20configuration&安培; FolderCTID =0x01200200770978C69A1141439FE559EB459D758000F9A0E3A95BA69146A17C2E80209ADC21¤tviews= 135 以上来自于谷歌翻译 以下为原文 I expect it is similar to the STM32 implementation. ie top 11 bit are the ID, assuming bits in transmission order, high order first. You could review these, and the reference material for your part. [DEAD LINK /public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/Flat.aspx?RootFolder=/public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/STM32%20CAN%20acceptance%20mask&FolderCTID=0x01200200770978C69A1141439FE559EB459D7580009C4E14902C3CDE46A77F0FFD06506F5B¤tviews=79]https://my.st.com/public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/Flat.aspx?RootFolder=/public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/STM32%20CAN%20acceptance%20mask&FolderCTID=0x01200200770978C69A1141439FE559EB459D7580009C4E14902C3CDE46A77F0FFD06506F5B¤tviews=79 [DEAD LINK /public/STe2ecommunities/mcu/Lists/STM32Java/Flat.aspx?RootFolder=/public/STe2ecommunities/mcu/Lists/STM32Java/STM32F4%20-%20can%20bus%20Id%20filters%20configuration&FolderCTID=0x01200200770978C69A1141439FE559EB459D758000F9A0E3A95BA69146A17C2E80209ADC21¤tviews=135]https://my.st.com/public/STe2ecommunities/mcu/Lists/STM32Java/Flat.aspx?RootFolder=%2Fpublic%2FSTe2ecommunities%2Fmcu%2FLists%2FSTM32Java%2FSTM32F4%20%2D%20can%20bus%20Id%20filters%20configuration&FolderCTID=0x01200200770978C69A1141439FE559EB459D758000F9A0E3A95BA69146A17C2E80209ADC21¤tviews=135 |
2906 浏览 1 评论
3290 浏览 1 评论
1870 浏览 1 评论
3724 浏览 6 评论
6134 浏览 21 评论
GMT+8, 2025-3-9 22:01 , Processed in 0.708198 second(s), Total 77, Slave 61 queries .
