我目前正在尝试实现一个系统,它允许我用一个单一的ARDUNO来在多个PSoC 049上更新固件。不幸的是,我真的很想把引导程序的主机代码移植到ARDUINO。
是否可以使用我现有的I2C总线来处理HSSP,如果我将引脚设置为SWD,然后在BooDeject项目中将它们切换回I2C? 以上来自于百度翻译 以下为原文 I am currently trying to implement a system that allows me to update the firmware on several PSOC 049's over I2C with a single arduino. Unfortunately I am really struggling to port the bootloader host code to arduino. Is it possible to use my existing I2C Bus to handle HSSP if I set the pins to SWD, and then in the bootloadable project switch them back to being for I2C? |
嗨,杰米,
听起来可能。 你使用的是哪种PSoC设备?我记得PSOC4000/4100/4200的SWD端口可以用EZI2C端口复制。 对于PSoC040S/PSoC4100S,您可以将I2C引脚与外部SWD接口连接,因此,如果您使用MIXPRO-3作为调试器,则不需要在编程之后切换I2C和SWD的硬件连接。 关于主持人…它要求主机支持软件SWD(当编程)和I2C(编程之前和之后)切换。我想你可以联系ARDUINO就如何进行这种转换。 谢谢, 赖安 以上来自于百度翻译 以下为原文 Hi Jamie, It sound possible. Which PSoC device are you using? I remember SWD port of PSoC4000/4100/4200 could be duplicated with EzI2C port. For PSoC4000S/PSoC4100S, you can connect I2C pins to SWD interface externally, so that you don't need to switch hardware connections of I2C and SWD after programming, if you are using MiniProg-3 as debugger. Regarding the host.... it requires the host to support software SWD(when programming) and I2C(before and after programming) switching. I think you can contact Arduino for how to make this kind of switch. Thanks, Ryan |
741个成员聚集在这个小组
加入小组2002 浏览 1 评论
1761 浏览 1 评论
3545 浏览 1 评论
1696 浏览 6 评论
1466 浏览 1 评论
273浏览 2评论
170浏览 2评论
355浏览 2评论
299浏览 2评论
487浏览 2评论
GMT+8, 2024-9-20 15:40 , Processed in 1.917178 second(s), Total 45, Slave 40 queries .
