嗨,
如何在设备视图中查看特定资源,无论它们是否被使用, 例如,我想看看设备中所有BUFG的数量和位置 或者,如果我想比较我在设计中使用的BUFG,但也希望看到那些未按顺序使用的BUFG,我可以正确地设置约束 对于MMCME,BRAM,HARD-IP(PCIE),MULT-DSP等任何其他特定资源也是如此 谢谢 以上来自于谷歌翻译 以下为原文 Hi, How can I see in the Device View specific resources regardless if they are used or not, For example I want to see how many and where are ALL the BUFG in the device Or if I want to compare the BUFG I'm using in my design but also want to see the ones which are not used in order I can place constraints properly The same for any other specific resources like MMCME, BRAMs, HARD-IP (PCIE), MULT-DSP , etc Thanks |
4个回答
假设您正在使用Vivado(您没有明确说明......),这些资源始终在设备视图中可见。
诀窍在于弄清楚要去哪里看! 未使用的资源(甚至是已使用的资源)可以通过其“站点”找到。 因此,例如,您可以使用该命令选择BUFGCTRL select_objects [get_sites BUFG *] 这将选择裸片视图中的对象 - 您可以看到所选对象并放大它们,或使用适合选择(在2017.1中似乎已从GUI中删除,但您可以使用F9键) Avrum 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Assuming you are using Vivado (you don't explicitly say so...), these resources are always visible in the device view. The trick is in figuring out where to look! Unused resources (and even used resources) can be found by their "site". So, for example, you can select the BUFGCTRLs by using the command select_objects [get_sites BUFG*] This will select the objects in the die view - you can see the selected objects and zoom in on them, or use the Fit Selection (which appears to be gone from the GUI in 2017.1, but you can use the F9 key instead) Avrum View solution in original post |
诀窍在于弄清楚要去哪里看! 未使用的资源(甚至是已使用的资源)可以通过其“站点”找到。 因此,例如,您可以使用该命令选择BUFGCTRL select_objects [get_sites BUFG *] 这将选择裸片视图中的对象 - 您可以看到所选对象并放大它们,或使用适合选择(在2017.1中似乎已从GUI中删除,但您可以使用F9键) Avrum 以上来自于谷歌翻译 以下为原文 Assuming you are using Vivado (you don't explicitly say so...), these resources are always visible in the device view. The trick is in figuring out where to look! Unused resources (and even used resources) can be found by their "site". So, for example, you can select the BUFGCTRLs by using the command select_objects [get_sites BUFG*] This will select the objects in the die view - you can see the selected objects and zoom in on them, or use the Fit Selection (which appears to be gone from the GUI in 2017.1, but you can use the F9 key instead) Avrum |
@ pumaju1808,
除了avrum帖子,您还可以打开精心设计/合成/实现的设计并搜索站点并使用Site_Type属性。 --Syed -------------------------------------------------- -------------------------------------------请注意 - 请标记答案 如果提供的信息有用,请“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢Kudos .------------------------ -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 @pumaju1808, Additional to avrum post, you can also open elaborated/synthesized/implemented design and search for sites and use Site_Type properties. --Syed --------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. --------------------------------------------------------------------------------------------- |
谢谢Syedz!
我只想分享额外的信息: 通过这种方式,您可以发现所有特定资源,也可以在结果窗口中,在“单元格”列中,您可以看到在您的设计中放置/使用了哪些(单元格== 1),哪些不是(单元格== 0) 以上来自于谷歌翻译 以下为原文 Thanks Syedz! I just want to share extra information: In this way you can spot ALL specific resources and also in the results windows, in "Cells" column you can see which ones are placed/used in your design (Cell==1) and which ones are not (Cells==0) |
2370 浏览 7 评论
2786 浏览 4 评论
2255 浏览 9 评论
3330 浏览 0 评论
2420 浏览 15 评论
743浏览 1评论
531浏览 1评论
344浏览 1评论
747浏览 0评论
1948浏览 0评论
GMT+8, 2024-11-14 13:14 , Processed in 1.053691 second(s), Total 52, Slave 46 queries .
