电子发烧友论坛扫一扫,分享给好友
这似乎与您的操作系统有关。
确保您的硬件和软件要求符合要求https://www.xilinx.com/support/documentation-navigation/design-hubs/dh0013-vivado-installation-and-licensing-hub.html只是google错误消息您将操作系统 相关问题 谢谢和RegardsBalkrishan ----------------------------------------------- ---------------------------------------------请将帖子标记为 一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 this seems related to your OS. make sure your are meeting the hardware and software requirement https://www.xilinx.com/support/documentation-navigation/design-hubs/dh0013-vivado-installation-and-licensing-hub.html Just google the error message you will OS related issuesThanks and Regards Balkrishan -------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helped resolve your query. Give kudos in case a post in case it guided to the solution.View solution in original post |
这似乎与您的操作系统有关。
确保您的硬件和软件要求符合要求https://www.xilinx.com/support/documentation-navigation/design-hubs/dh0013-vivado-installation-and-licensing-hub.html只是google错误消息您将操作系统 相关问题 谢谢和RegardsBalkrishan ----------------------------------------------- ---------------------------------------------请将帖子标记为 一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 this seems related to your OS. make sure your are meeting the hardware and software requirement https://www.xilinx.com/support/documentation-navigation/design-hubs/dh0013-vivado-installation-and-licensing-hub.html Just google the error message you will OS related issuesThanks and Regards Balkrishan -------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helped resolve your query. Give kudos in case a post in case it guided to the solution. |
我使用的是Windows Server 2008 R2 Standard。
Microsoft在2008年专业开发人员大会上推出了Windows Server 2008 R2作为Windows 7的服务器变体。 有32GB的内存(足够xcvu065)。 Vivado 2012,2014,2015没有这种问题。 以上来自于谷歌翻译 以下为原文 I am using Windows Server 2008 R2 Standard . Microsoft introduced Windows Server 2008 R2 at the 2008 Professional Developers Conference as the server variant of Windows 7. Have 32GB of memory(enough for xcvu065). There was no this kind of issues with Vivado 2012,2014,2015. |
嗨,您能告诉您最后关注的步骤吗?
我可以尝试在本地重现这个问题。这个问题特定于deisgn吗? 您是否尝试过设计示例?也可以尝试使用其他任何机器?以上信息有助于缩小问题范围。谢谢,Yash 以上来自于谷歌翻译 以下为原文 Hi, Can you please inform the steps that you are following at your end? I can try to reproduce the issue locally. Is this issue specific to deisgn? Did you tried with example design? Also can try using any other machine? The above information help to narrow down the issue. Thanks, Yash |
你好。
我得到此错误的步骤: 1.构建设计。 (综合 - >实现 - >写比特流) 2.打开已实施的设计 3.打开时间报告(工具 - >时间 - >报告时间摘要) 4.选择设计中的任何路径(例如,来自时钟内路径的某些路径)并且Vivado正在静默停止。 没有错误消息 5.打开任何dcp(放置或布线设计) 我得到R6025错误。 在第4步之后,我只能打开合成dcp(通过“Open Checkpoint”或“Open Synthesized Design”)。 我曾尝试在第5步打开示例设计 - 仍然是R6025。 现在无法重启服务器。 我将在第4步尝试exdes,稍后将在另一台PC上尝试。 感谢您的帮助。 以上来自于谷歌翻译 以下为原文 Hi. My steps to get this error: 1. Build design. (Synthesis->Implementation->Write Bitstream) 2. Open Implemented design 3. Open timing report (Tools->Timing->Report Timing Summary) 4. Select any path in design(For example some path from Intra-Clock Paths) And Vivado is halting silently. With no error message 5. Open any dcp with placing (placed or routed design) And im getting R6025 error. After 4th step i can open only synthesis dcp(via "Open Checkpoint" or "Open Synthesized Design"). I had tried to open example design at 5th step also - still R6025. Cant reboot server now. I will try exdes at 4th step and will try it at another PC later. Thank you for helping. |
2568 浏览 7 评论
2904 浏览 4 评论
2359 浏览 9 评论
3453 浏览 0 评论
2540 浏览 15 评论
2972浏览 1评论
700浏览 1评论
573浏览 1评论
864浏览 0评论
GMT+8, 2025-4-6 01:49 , Processed in 1.521667 second(s), Total 87, Slave 70 queries .
