如果BIOS中有多个活动的处理器核心,那么计算机无法再启动BIOS,就在主板徽标出现后,弹出蓝屏并重新启动计算机,如果设置活动核心数1,则
Windows正常启动。 购买后,一切都运行了10天,然后在压力测试AIDA64期间出现蓝屏。 错误总是不同的。 I7-8700K,Asrock z370 Extreme4,金士顿HyperXPredator2***8GB。 以上来自于谷歌翻译 以下为原文 If there are more than one active processor cores in bios, then the computer does not boot further bios, just after the motherboard logo appears, the blue screen pops up and the computer reboots, if you set the number of active cores 1, then the Windows boots up normally. After the purchase, everything worked perfectly for 10 days, then a blue screen popped up during the stress test AIDA64. Errors are always different. I7-8700K, Asrock z370 Extreme4, Kingston HyperX Predator 2***8GB. |
Hellolaur601感谢您加入英特尔®社区。您是否尝试过联系华擎*以将BIOS恢复为默认设置并验证是否需要更新BIOS更新?
希望这有帮助。 此致Leonardo C.Intel客户支持威廉希尔官方网站 人员与英特尔公司签订合同 以上来自于谷歌翻译 以下为原文 Hello laur601 Thank you for joining the Intel® community. Have you tried contacting ASRock* to restore BIOS to default settings and verify if there is any BIOS update require? Hope this help. Regards, Leonardo C. Intel Customer Support Technician Under Contract to Intel Corporation |
你好laur601I正在检查你的情况,想知道你是否需要进一步的帮助。
如果是这样,请不要犹豫回复.Regards,Leonardo C.Intel客户支持威廉希尔官方网站 人员与英特尔公司签订合同 以上来自于谷歌翻译 以下为原文 Hello laur601 I was checking your case and would like to know if you need further help. If so, please do not hesitate in replying back. Regards, Leonardo C. Intel Customer Support Technician Under Contract to Intel Corporation |
519浏览 0评论
GMT+8, 2024-12-25 02:19 , Processed in 0.755079 second(s), Total 78, Slave 62 queries .
