你好,
我现在设法从我的温度传感器读取模拟值,我现在想知道如何将该值(3643)转换为温度?我没有看到任何类型的公式如何用Vref(参考电压)计算该值以及我如何自己获得输入电压。你有什么想法我能做到这一点吗? 最好的祝福 #adc-vrefint #adc 以上来自于谷歌翻译 以下为原文 Hello, i now managed to reada analog value from my temperature sensor and i am now wondering how i can convert that value (3643) to a temperature? I didn't see any kind of formula how the value is calculated with Vref (reference Voltage) and how i can get the input voltage on its own. Do you have any ideas how i can do this? Best regards #adc-vrefint #adc |
请参阅多维数据集中的示例,例如STM32Cube_FW_L4_V1.6.0 Projects STM32L476RG-Nucleo Examples_LL ADC ADC_TemperatureSensor
可以在ll_adc lib中获得ADC值到温度的计算:__LL_ADC_CALC_TEMPERATURE 有关理论,请参阅AN3964 http://www.st.com/content/ccc/resource/technical/document/application_note/b9/21/44/4e/cf/6f/46/fa/DM00035957.pdf/files/DM00035957.pdf/jcr:内容/翻译/ en.DM00035957.pdf 希望它有所帮助 奥利维尔 以上来自于谷歌翻译 以下为原文 Refer to exemple in Cube eg STM32Cube_FW_L4_V1.6.0ProjectsSTM32L476RG-NucleoExamples_LLADCADC_TemperatureSensor Computation of ADC value to temperature is available in ll_adc lib : __LL_ADC_CALC_TEMPERATURE Refer to AN3964 for theory http://www.st.com/content/ccc/resource/technical/document/application_note/b9/21/44/4e/cf/6f/46/fa/DM00035957.pdf/files/DM00035957.pdf/jcr:content/translations/en.DM00035957.pdf Hope it help Olivier |
你好,我们又见面了
Gustamko.Master 关于STM32的第一个答案的道歉 对于STM8,相关软件示例和应用说明可在此处获得 https://my.st.com/content/my_st_com/en/products/embedded-software/mcus-embedded-software/stm8-embedded-software/stsw-stm8070.license%3d1485523987494.html http://www.st.com/content/ccc/resource/technical/document/application_note/46/07/39/dd/1d/f8/46/7a/DM00028336.pdf/files/DM00028336.pdf/jcr:内容/翻译/ en.DM00028336.pdf 注意:原始帖子包含大量线程对话,只能迁移到第9级 以上来自于谷歌翻译 以下为原文 Hi again Gustamko.Master Apology for my first answer about STM32 For STM8 relevant software exemple and application note are available here https://my.st.com/content/my_st_com/en/products/embedded-software/mcus-embedded-software/stm8-embedded-software/stsw-stm8070.license%3d1485523987494.html http://www.st.com/content/ccc/resource/technical/document/application_note/46/07/39/dd/1d/f8/46/7a/DM00028336.pdf/files/DM00028336.pdf/jcr:content/translations/en.DM00028336.pdf Note: the original post contained a large number of threaded conversations and was only able to be migrated to the 9th level |
2846 浏览 1 评论
3274 浏览 1 评论
1856 浏览 1 评论
3699 浏览 6 评论
6111 浏览 21 评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
403浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
495浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
323浏览 2评论
使用STM32F407VET6的USB2.0功能,发现ctl后芯片无数据返回,是什么原因可能导致的呢?
241浏览 2评论
用STM32G431开发工程,1.50版本的Package包文件无法输出项目工程
345浏览 2评论
GMT+8, 2025-2-12 09:45 , Processed in 1.225523 second(s), Total 49, Slave 43 queries .
