您好,我已经在应用程序注释中实现了一个dSPIC33 e引导加载程序。引导加载程序IVT是位于主应用程序中的跳转表的一系列跳转指令。主应用程序跳转表中填充有相关ISR的地址。这是预期的。Bootloader不使用中断,但是人们如何处理不可屏蔽的中断/异常。特别是当没有应用程序存在时?作为一种预防措施,在通过调试器加载Bootloader时,用零填充跳转表区域,但在部分重新编程的情况下,这无济于事。选项?在引导加载程序中实现非掩码?谢谢斯
以上来自于百度翻译 以下为原文 Hello, I have implemented a dsPIC33E bootloader in-line with the application notes. The bootloader IVT is a series of jump instructions to a jump table located in the main application. The main application jump table is populated with the address of the relevant ISR. This all works as expected. The bootloader does not use interrupts, but how do people handle non-maskable interrupts/exceptions. Particularly when there is no application present? As a precaution, I filled the jump table area with zeros when loading just the bootloader via debugger, but this doesn't help in the event of partial reprogramming. Options? Implement non-maskables in the bootloader? Thanks MS |
1 条评论
3个回答
你认为贴N次会有什么改进吗?关闭这个!
以上来自于百度翻译 以下为原文 Do you think posting n times improves anything ? Close this ! |
找到微芯片样本源代码文件“traps.c”或搜索“wherewasi”或地址陷阱
这些将提供堆栈返回跟踪以查找导致故障的指令。 Cartoon HD App Cartoon HD APK |
5248 浏览 9 评论
2036 浏览 8 评论
1956 浏览 10 评论
3217 浏览 3 评论
2264 浏览 5 评论
782浏览 1评论
676浏览 1评论
602浏览 1评论
684浏览 0评论
581浏览 0评论
GMT+8, 2024-12-26 12:51 , Processed in 1.558888 second(s), Total 83, Slave 67 queries .
