扫一扫,分享给好友
正如在一些线程中提到的,对于某些人来说,更新到PSoC创建者4.2的生产版本会导致项目不再构建。这就是正在发生的事情,以及如何解决这个问题。
PSoC Creator 4.2的发布版本与PDL 3.0.1的早期版本不兼容,更新器无法正确处理。如果你有一个早期版本的PDL 3.0.1安装(例如,从beta社区),然后更新你的创建者安装,事情就会中断。 我们知道是什么引起了这个问题,我们正在努力确保根本原因是尽快确定的,但这不会是瞬间的。 解决办法 转到PDL产品页面,向下滚动到相关文件部分,并下载文件“下载PDL 3.0.1完整的安装程序.exe”。运行安装程序更新您的PDL。 吉姆特鲁多 高级应用工程师 消息编辑:James Trudeau,提供了一个更容易的解决办法,因为它已经到位。 以上来自于百度翻译 以下为原文 As noted in a couple of threads, for some people, updating to the PSoC Creator 4.2 production release causes projects to no longer build. Here's what's happening, and how to work around the problem. The released version of PSoC Creator 4.2 is incompatible with earlier versions of PDL 3.0.1 The updater does not handle this correctly. If you have an earlier version of PDL 3.0.1 installed (from the Beta community, for example), and you update your Creator installation, things break. We know what caused the problem, and we are working to make sure the root cause is fixed ASAP, but that won't be instantaneous. WORKAROUND Go to the PDL product page, scroll down to the Related Files section, and download the file "Download PDL 3.0.1 Complete Setup.exe" . Run the installer to update your PDL. Jim Trudeau Senior Principal Applications Engineer Message was edited by: James Trudeau, providing an easier workaround now that it's in place. |
754个成员聚集在这个小组
加入小组2105 浏览 1 评论
1851 浏览 1 评论
3669 浏览 1 评论
1786 浏览 6 评论
1536 浏览 1 评论
570浏览 2评论
423浏览 2评论
437浏览 2评论
384浏览 2评论
915浏览 2评论
GMT+8, 2024-12-23 20:27 , Processed in 0.667783 second(s), Total 41, Slave 36 queries .
