大家好,
什么是“无空白的针脚”? 谢谢! 以上来自于谷歌翻译 以下为原文 Hi All, What is "blankless pins"? Thank you! |
5个回答
@ dmitry1417
VRP和VRN引脚 -------------------------------------------------- -------------------------------------------请在发布前进行谷歌搜索, 您可能会找到相关信息。请留下帖子 - “接受为解决方案”,如果提供的信息有用且回复,请给予赞誉 以上来自于谷歌翻译 以下为原文 @dmitry1417 VRP and VRN pins --------------------------------------------------------------------------------------------- Please do google search before posting, you may find relavant information. Mark the post - "Accept as solution" and give kudos if information provided is helpful and reply oriented |
什么是VRP和VRN引脚?
你能解释一下还是参考一个文件? 以上来自于谷歌翻译 以下为原文 What are the VRP and VRN pins? Could you please explane or refer to a doc? |
你好@ dmitry1417
查看此论坛帖子:https://forums.xilinx.com/t5/Virtex-Family-FPGAs/VRN-VRP/td-p/465170 谢谢, 维奈 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi @dmitry1417 Check this forums thread: https://forums.xilinx.com/t5/Virtex-Family-FPGAs/VRN-VRP/td-p/465170 Thanks, Vinay -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
@ dmitry1417
您可以参考UG471“Xilinx DCI”部分了解更多详情 -------------------------------------------------- -------------------------------------------请在发布前进行谷歌搜索, 您可能会找到相关信息。请留下帖子 - “接受为解决方案”,如果提供的信息有用且回复,请给予赞誉 以上来自于谷歌翻译 以下为原文 @dmitry1417 You can refer UG471 "Xilinx DCI" section for more details --------------------------------------------------------------------------------------------- Please do google search before posting, you may find relavant information. Mark the post - "Accept as solution" and give kudos if information provided is helpful and reply oriented |
你的意思是“无银行的针脚”吗?
- 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。 以上来自于谷歌翻译 以下为原文 do you mean "bankless pins" by any chance?- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. |
2612 浏览 7 评论
2940 浏览 4 评论
2380 浏览 9 评论
3485 浏览 0 评论
2563 浏览 15 评论
3155浏览 1评论
736浏览 1评论
622浏览 1评论
GMT+8, 2025-4-30 04:00 , Processed in 1.380979 second(s), Total 85, Slave 69 queries .
