亲爱的大家,
我们在其中一种电路板设计中使用了英特尔82580芯片,旁边还有一个eeprom。 我们发现将FW加载到eeprom中的解决方案是在焊接过程之前加载它,即在之前编程eeprom并进行焊接, 所以我想找出以下内容: - 我们应该使用.bin还是.hex提供的FW? - 是否有工具通过PCIe连接更新eeprom? - 是否有工具通过提供的jtag连接更新eeprom? 提前致谢。 哈坎 以上来自于谷歌翻译 以下为原文 Dear All, we used an Intel 82580 chip in one of our board designs, and have an eeprom next to it. The solution we found to load the FW into the eeprom is to load it before the soldering process, i.e. programm the eeprom before and the do soldeing, So I wanted to find out the following: - should we use the .bin or the .hex provided as FW? - is there a tool to update the eeprom over PCIe connection? - is there a tool to update the eeprom over the jtag connection provided? Thanks in advance. Hakan |
您好Hsakman_69,感谢您在英特尔社区发帖。
您可以在英特尔嵌入式社区中找到更快的支持发布。 如果您在之前的帖子中找不到答案,请尝试检查嵌入式社区并在那里发布问题。 如果您有任何其他问题,请告诉我们。最好的问候,丹尼尔D. 以上来自于谷歌翻译 以下为原文 Hello Hsakman_69, Thank you for posting in Intel Communities. You may be able to find faster support posting in the Intel Embedded Communities. Please try checking the Embedded Community and post a question there if you cannot find the answer in a previous post. If you have any other questions please let us know. Best regards, Daniel D |
GMT+8, 2025-2-24 17:22 , Processed in 0.442680 second(s), Total 42, Slave 37 queries .
