您好,我的集成显卡存在问题。
一年前,我的专用GPU停止工作,我已经禁用它,所以我可以毫无问题地使用我的笔记本电脑。 我今天试图让它再次运作,但没有结果。 再次禁用它,我的系统启动,然后我注意到我的推荐分辨率是1024x768(本机是1600x900),我只能在这两者之间进行选择。 然后我启动了Deus Ex Human Revolution并弹出设置菜单(当你第一次运行游戏时打开),只有我能选择的显示适配器是Microsoft Basic Renderer 1和2,而且刷新率也是64Hz。 当我打开游戏时,性能变得更糟,然后我尝试让我的专用GPU再次工作。 Doom(1993)基于OpenGL的源端口也不起作用“OpenGL没有加速!”。 更奇怪的是,设备管理器中唯一的显示适配器是Intel HD 3000.此外,英特尔图形和媒体控制面板和驱动程序& 支持助理托盘无法正常工作。 我知道它不支持Windows 10,但它在我的tomfoolery与专用GPU之前工作得很好。 有解决方案吗? 以上来自于谷歌翻译 以下为原文 Hello, I have an issue regarding my integrated graphics card. A year ago my dedicated GPU stopped working and I've disabled it so I can use my laptop without issues. I've tried to make it work again today, but with no results. Disabled it again, my system booted up, and then I've noticed that my Recommended resolution is 1024x768 (native is 1600x900), and I can only choose between these two. Then I started Deus Ex Human Revolution and the setup menu popped up (which opens when you run the game for the first time) and only display adapters I could pick were Microsoft Basic Renderer 1 and 2, and also my refresh rate was 64Hz. When I opened the game the performance was way worse before I tried making my dedicated GPU to work again. Doom (1993) OpenGL based source ports also don't work as "OpenGL is not accelerated!". What's even weirder is that the only display adapter in Device Manager is Intel HD 3000. Also, the Intel Graphics and Media Control Panel and Driver & Support Assistant Tray aren't working. I know that it's not supported for Windows 10, but it worked just fine before my tomfoolery with the dedicated GPU. Is there a solution? |
3个回答
Windows 10不支持HD 3000图形,从未使用过。
支持英特尔®图形产品的操作系统 您一直在使用Microsoft通用驱动程序。 英特尔或微软专门针对Windows 10 for HD 3000显卡提供驱动程序。 这也意味着Windows 10不支持您的处理器。 您最好的办法是获得Windows 10支持的新(笔记本电脑)。 文件 以上来自于谷歌翻译 以下为原文 HD 3000 graphics are not supported on Windows 10, and have never been. Supported Operating Systems for Intel® Graphics Products You have been using the Microsoft generic driver. There is no driver available from Intel, or Microsoft specifically for Windows 10 for HD 3000 graphics. This also means your processor is not supported on Windows 10. Your best bet is to get a new(er) laptop that is supported on Windows 10. Doc |
实际上有一些来自Microsoft Update Catalog for Intel HD Graphics 3000的Win10兼容图形驱动程序。使用版本9.17.10.4229或9.17.10.4459用于HD 3000,但确实意识到MS的这些驱动程序具有基本功能,并且不具备所有选项 全功能的驱动程序是为Windows 7& 8.x中 以上来自于谷歌翻译 以下为原文 actually there are some Win10 compatible graphics drivers from Microsoft Update Catalog for Intel HD Graphics 3000. use either version 9.17.10.4229 or 9.17.10.4459 for the HD 3000 but do realize that these drivers from MS have basic functions and will not have all the options that the full-featured drivers have that were made for Windows 7 & 8.x. |
xxsxsjd 发表于 2018-10-29 08:22 但是,HD 3000(和处理器)仍然不受支持。 文件 以上来自于谷歌翻译 以下为原文 However, HD 3000 (and the processor) are still unsupported. Doc |
GMT+8, 2025-4-29 20:00 , Processed in 0.721382 second(s), Total 79, Slave 63 queries .
