随着ST&飞思卡尔联盟和一些芯片是一样的,我不知道是否
mpc563mzp66就是其中之一?如果是,我如何找出ST部件名称?据我所知,它不像只用S交换前导M那么容易。 以上来自于谷歌翻译 以下为原文 With the ST & Freescale alliance and some chips being the same, I wonder if mpc563mzp66 is one of them? If it is, how would I figure out the ST part name? As far as I know it is not as as easy as just swapping the leading M with an S. |
你好,
不幸的是,ST没有mpc563mzp66等效零件号,因为该产品不包含在联盟范围内开发的产品中。 无论如何,您可以使用Home - >部分中的产品选择器找到符合您需求的ST产品。感觉和电力和汽车产品 - >汽车微控制器 - > SPC5 32位汽车MCU(直接网址http://www.st.com/web/en/catalog/sense_power/FM2098/SC963 ) 一般来说,确定一个等同于FSL的ST产品是正确的,在S中交换M是不够的:所以我们提供的是ST WEB页面中的交叉引用搜索引擎。 它与用于搜索ST WEB(位于每个ST WEB页面的右上角)相同:您只需输入FSL部件号,在开始搜索之前,从''部件号/关键字切换搜索选项''到''交叉参考''。 无论如何,如有疑问,只需在论坛中输入另一个项目即可。 以上来自于谷歌翻译 以下为原文 Hello, unfortunately ST has no mpc563mzp66 equivalent part number since the product is not included in the ones developed in the scope of the alliance. Anyway you may find an ST product matching your needs by using the product selector in the section Home -> Sense & Power and Automotive Products -> Automotive Microcontrollers ->SPC5 32-bit Automotive MCUs (direct URL http://www.st.com/web/en/catalog/sense_power/FM2098/SC963 ) Generally speaking it is true that to identify an ST product equivalent to a FSL one, it is not enough to swap M in S: so what we are offering is a cross reference sear engine in the ST WEB pages. It is the same used to search on the ST WEB (positioned on top right of every ST WEB pages): you have simply to enter the FSL part number, and before starting the search, switch the search option from ''Part Number/ Keyword'' to ''Cross Reference''. Anyway, in case of doubt, just enter another item in the forum. |
2733 浏览 1 评论
3241 浏览 1 评论
1810 浏览 1 评论
3650 浏览 6 评论
6038 浏览 21 评论
1339浏览 4评论
201浏览 3评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
350浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
443浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
274浏览 2评论
GMT+8, 2024-12-24 00:38 , Processed in 0.946735 second(s), Total 76, Slave 60 queries .
