您好,我使用的是带有10.20.02最新固件的PNA-X Win 7版本。
我遇到的问题是回忆起在Win-XP PNA-X上创建的.csa文件。 我第一次回想起来,没关系。 但是,对于之后的第二次和随后的召回,我总是会收到一个对话窗口警告'上面列出的校准集将覆盖现有的校准集'消息。 但是,我没有修改任何可以保证错误对话框消息的校准集。 我怀疑是,不知何故,有一些独特的Win-XP标识符会导致win 7固件认为正在将唯一的calset复制到系统中。 如果有人能够证实这一点并可能解决这个问题,那就太棒了。 谢谢,rok 以上来自于谷歌翻译 以下为原文 Hello, I am using a PNA-X Win 7 version with 10.20.02 latest firmware. The issue I am encountering is with respect to recalling a .csa file that was created orginally on a Win-XP PNA-X. The first time I recall it, it was okay. However, for the 2nd and any subsequent recalls after that, I always get a dialog window warning 'The calsets listed above will overwrite existing calsets' message. However, I am not modifying any calsets that would warrant that error dialog message. My suspicion is that somehow, there is some unique Win-XP identifier that causes the win 7 firmware to think a unique calset is being copied to the system. If someone can confirm this and possibly fix this, that would be great. Thanks, rok |
6个回答
如果您在win 7框中记住XP生成的.csa文件然后重新保存(可能使用新名称),然后再调用新的csa文件,则警告消息应该消失。
以上来自于谷歌翻译 以下为原文 if you recall your XP generated .csa file in the win 7 box and then resave it (maybe with a new name), and then recall the new csa file thereafter, the warning message should go away. |
Topcbpcba 发表于 2018-10-26 20:05 你好,谢谢你的回复。 我尝试了你的建议,但仍然遇到弹出窗口的同样问题。 复制问题应该非常简单(即在带有附加校准文件的Win-XP PNA-X上创建一个csa文件,并在Win 7 PNA-X上加载两次)。 韩国 以上来自于谷歌翻译 以下为原文 Hi, Thanks for the reply. I tried your suggestion, but still get the same problem with the popup. It should be very simple to duplicate the problem (i.e. create a csa file on a Win-XP PNA-X with an attached calibration file and load it twice on the Win 7 PNA-X). rok |
蓝色冰汐 发表于 2018-10-26 20:15 嗨Rok,我可以在我有机会换掉PNA-X上的磁盘时尝试一下,但是如果你可以共享你生成的XP生成的csa文件,它可能会更高效,我们也许能够调查它 更早。 如果您不想公开发布,只需通过私信发送给我。 以上来自于谷歌翻译 以下为原文 Hi Rok, I can try that as soon as I get an opportunity to swap out the disks on my PNA-X, but if you can share your XP generated csa file, it might be more efficient and we might be able to look into it sooner. if you don't want to post it publicly, just sent it to me via private message. |
Topcbpcba 发表于 2018-10-26 20:21 嗨,私信系统不允许我附加任何文件,所以我必须在这里发布。 韩国 以上来自于谷歌翻译 以下为原文 Hi, The private message system wouldn't let me attach any files, so I have to post it here. rok 附件
嗨Rok,我确实确认这个问题出现在A.10.20.02中,不幸的是它仍然在A.10.20.03,这是下一个正在接受QA的待处理版本。 好消息是问题实际上已经解决了我们正在研究的最新测试版代码(我刚刚自己测试过)。 即将发布的03 bugfix版本在QA周期中太过分了,因为我们冒险为非关键缺陷添加新代码(顺便说一下,覆盖消息是无害的。你的cal数据) csa文件与您第一次调用后在PNA中的校准数据相同,唯一的区别是时间戳,这就是您每次都收到该消息的原因)。 我们计划在大约一个月左右的时间内推出另一个版本,这个问题将在其他新功能出现时解决。 以上来自于谷歌翻译 以下为原文 Hi Rok, I did confirm that this problem is in A.10.20.02 and unfortunately it is also still in A.10.20.03, which is the next pending release undergoing QA right now. the good news is that the problem is actually resolved in our latest beta code that we are working on (I just tested it myself). the 03 bugfix release that is just about to come out is too far into the QA cycle for us to risk adding new code to it for a non-critical defect (and by the way, the overwrite messages are harmless. the cal data in your csa file is identical to the cal data you have in the PNA after your first recall, the only difference is the time stamps, which is why you are getting that message every time). We have another release planned in a about a month or so and that will have the fix to this problem among other new features when it comes out. |
Topcbpcba 发表于 2018-10-26 20:55 嗨daras,感谢您确认并验证问题。 只要工作中有修复,那就没问题了。 谢谢,rok 以上来自于谷歌翻译 以下为原文 Hi daras, Thanks for confirming and verifying the problem. As long as there is a fix in the works, that would be fine. Thanks, rok |
1294 浏览 0 评论
2377 浏览 1 评论
2199 浏览 1 评论
2068 浏览 5 评论
2955 浏览 3 评论
1131浏览 1评论
759浏览 0评论
939浏览 0评论
1296浏览 0评论
GMT+8, 2024-12-27 00:54 , Processed in 1.881133 second(s), Total 85, Slave 69 queries .
