嗨,我的程序需要定期修改存储在SST内存中的一个字节。唯一的可能是读取4KB,修改所选字节,ErES扇区并重写整个?它需要4KB RAM,而我没有那么多:
以上来自于百度翻译 以下为原文 Hi, My program needs to periodically modify a single byte stored in the SST memory. Is the only possibility to read 4kb, modify the selected byte, erese sector and rewrite the whole? It requires 4kb RAM and I do not have that much :( |
我想,我可以像在RAM中缓存一样使用每个扇区,但是我想知道是否有更好的方法。内存由多个函数使用,在这种情况下,每个存储器都需要不同的内存服务软件。
以上来自于百度翻译 以下为原文 I guess I can use, for example, as much of each sector as I am able to cache in ram. But I wonder if there's a better way. The memory is used by several functions and each of them would require a different memory service software in this case. |
5064 浏览 9 评论
1945 浏览 8 评论
1879 浏览 10 评论
3104 浏览 3 评论
2175 浏览 5 评论
615浏览 1评论
484浏览 1评论
344浏览 1评论
515浏览 0评论
422浏览 0评论
GMT+8, 2024-9-20 22:22 , Processed in 1.194452 second(s), Total 80, Slave 64 queries .
