为什么Keysight决定在不使用可下载的编程手册的情况下强制更改编程语法的新界面?
我们购买了带有PTB选项的DCA-X,但发现该选项仅适用于FlexDCA接口。 这意味着我们需要更新驱动程序以支持新语法。 这导致了对FlexDCA编程手册的搜索,但事实并非如此。 您需要在DCA上使用内部帮助文件。 我对这种设备的访问受限,这减慢了驱动程序的开发速度。 他们是否尝试从帮助文件中剪切语法并将其粘贴到您的代码中,就像您可以将PDF文件一样? 我试图想出一个没有成功发布文档的充分理由。 有没有人对这种新的支持理念有任何见解? 以上来自于谷歌翻译 以下为原文 Why did Keysight decide to force a new interface which changes the programming syntax without having a downloadable programming manual? We bought a DCA-X with PTB option only to find out that option is only available in the FlexDCA interface. This means we need to update our drivers to support the new syntax. That has led to a search for the FlexDCA programming manual which it turns out, doesn't exist. You need to use an internal help file on the DCA. I have limited access to this equipment which is slowing development of the driver. Have they tried cutting syntax from the help file and pasting it into your code like you can a pdf file? I have tried to think of a good reason not to publish the document without success. Does anyone have any insight into this new support philosophy? |
86100D上的所有新开发都专注于FlexDCA接口。
是德科技不再致力于增强旧版UI的功能。 所有用户指南,帮助和程序员指南均可在在线帮助中找到。 维护在线帮助和任何用户指南的纸质副本非常耗时,并且决定仅提供在线帮助,因此无法提供PDF版本。 可以从86100D固件更新页面下载在线帮助文件,并使用.chm阅读器保存到PC或平板电脑以供参考。 从同一台PC上的在线帮助切换到用户开发环境非常简单。 http://www.keysight.com/main/redirector.jspx?action=ref&nid=-536902447.0.00&lc=eng&cc=US&ckey=2038334&cname=EDITORIAL&nfr=-536902447.937136包含在 在线帮助编程参考是FlexDCA远程命令的兼容遗留表,可帮助您更轻松地进行转换。 此外,FlexDCA UI包含一个SCPI记录器,可用于记录SCPI命令,以便在86100D前面板上手动执行步骤。 这通常是查找特定测量或设置的远程命令的最简单方法。 可以根据需要保存和使用一系列命令。 以上来自于谷歌翻译 以下为原文 All new development on 86100D is focused toward the FlexDCA interface. Keysight is no longer working on enhancements for the legacy UI. All of the users guide, help and programmers guide are available in the online help. It is very time consuming to maintain both online help and a paper copy of any users guide and the decision was made to only offer online help so a PDF version is not available. The online help files can be downloaded from the 86100D firmware update page and saved to a PC or a tablet with a .chm reader for reference. It is pretty simple to cut and past from the online help to the users development environment on the same PC. http://www.keysight.com/main/redirector.jspx?action=ref&nid=-536902447.0.00&lc=eng&cc=US&ckey=2038334&cname=EDITORIAL&nfr=-536902447.937136 Included in the online help programming reference is a table of compatible legacy to FlexDCA remote commands to help you transition more easily. In addition, the FlexDCA UI contains a SCPI recorder which can be used to record the SCPI commands for steps taken manually on the 86100D front panel. This is often the easiest way to find a remote command for a specific measurement or setting. A series of commands can be saved and used as needed. |
你好,当我开始使用PTB编程我的DCA-X主机时遇到了类似的问题。
我发现使用SCPI录音机非常有用。 我激活它并手动提供测量的所有步骤(按下相应的命令按钮),并将SCPI窗口中显示的相应命令提供给我的VISA写入条目。 如果您使用自定义时钟,请注意设置PTB参考时钟(不是PTB提供的列表之一)。 还有一个建议:处理时间,因为手动向范围提供命令比花在编程上花费更长的时间问候Davide 以上来自于谷歌翻译 以下为原文 Hello I had the similar problems when i started to program my DCA-X mainframe with PTB. I found really useful using the SCPI recorder. I activated it and provided manually all the steps for my measurement (pressing corresponding command buttons) and provided the corresponding commands shown in the SCPI window to my VISA Write entries. Take care in setting PTB reference clock in case you use a custom one (not one of the list provided along with PTB). Just one more suggestion: take care of timing as manually providing commands to the scope take way longer time than doing it programmatically Regards Davide |
1385 浏览 0 评论
2419 浏览 1 评论
2268 浏览 1 评论
2105 浏览 5 评论
3019 浏览 3 评论
1426浏览 1评论
827浏览 0评论
1195浏览 0评论
1385浏览 0评论
GMT+8, 2025-2-24 19:43 , Processed in 1.169307 second(s), Total 44, Slave 39 queries .
