有没有人见过这个问题?
- 在我的程序结束时,我有两个面板,我想保存到两个excel电子表格中。 我打开一个电子表格,保存适当的图像然后关闭该电子表格并重复第二个。 问题是,当发送第二个图像时,第一个电子表格也会更新,第二个图像替换第一个图像 - 即使我暂停程序并重命名第一个电子表格。 欢迎任何建议! 以上来自于谷歌翻译 以下为原文 Has anyone seen this problem? - At the end of my program, I have two panels which I want to save into two excel spreadsheets. I open one spreadsheet, save the appropriate image then close that spreadsheet and repeat for the second. Problem is that when sending the second image the first spreadsheet also gets updated with the second image replacing the first - even if I pause the program and rename the first spreadsheet. Any suggestions welcome! |
对我来说,这听起来像是粘贴到图像的链接,其内容从一个图像变为另一个图像,而不是粘贴在位图中。
也许您可以发布一个显示问题的简单示例? 以上来自于谷歌翻译 以下为原文 To me it sounds like you are pasting in a link to an image the content of which changes from one to the other, rather than pasting in a bitmap. Maybe you could post a simple example showing the problem? |
谢谢迈克 - 你是对的 - 它在默认的临时文件中保存了一个.jpg,链接到每个电子表格。 我创建了一个例程,它将xlib.ImageSettiings中的文件路径设置为与具有相同文件名的电子表格相同。 这现在有效,虽然我最终得到了.jpg以及电子表格中的图像,但没关系。 再次感谢,基思 以上来自于谷歌翻译 以下为原文 Thanks Mike - You're right - it is saving a .jpg in the default temp file which is linked to each spreadsheet. I've created a routine which sets the filepath in xlib.ImageSettiings to be the same as the spreadsheet with the same filename. This now works, although I do end up with the .jpg as well as the image in the spreadsheet but that's ok. Thanks again, Keith |
1396 浏览 0 评论
2424 浏览 1 评论
2275 浏览 1 评论
2113 浏览 5 评论
3028 浏览 3 评论
1494浏览 1评论
840浏览 0评论
1257浏览 0评论
1397浏览 0评论
GMT+8, 2025-3-7 00:11 , Processed in 1.374465 second(s), Total 79, Slave 63 queries .
