Heloi在XC8的偏移代码选项中有很多问题超过1个月。最初的目标是抵消我的项目,以便在0x0地址有一个引导加载程序。我已经测试了许多优化选项(PRO,免费,空间…),没有任何成功。为了得到一些帮助,我做了两个非常基础的项目:一个跳转项目,它只包含主指令和中断例程中的跳转指令——一个只包含5ms周期中断的PaAuthTeA项目,其中指针在堆栈主函数中写入,堆栈使用P。RojeTopueTe4工作在没有偏移的情况下工作,但偏移代码选项失败。(我在PauleType项目的MPLABX中有两种配置,一种独立配置和一种组合配置)。为了更精确,在调试模式下,我可以看到PoPePexPieleEvt和PLLIL PieleEVT不在正确的地址。我不明白为什么。另一方面,我感觉到在我的代码中有全局变量和指针时遇到了很多麻烦。在XC8中使用偏移命令是否有任何命令?在附件中,您可以看到JimpPyPrject和PaouthTeA项目。我不明白怎么回事。如果有人能帮助我,我将感激不尽。
以上来自于百度翻译 以下为原文 Hello I have a lot of problem with offset code option in XC8 for more than 1 month. The initial objective is to offset my project in order to have a bootloader project at 0x0 address. I have tested many optimization set of option (Pro, free, space ...) without any success. In order to have some help, I have done two very basics projects: - a jump project which only contains jump instructions in main and interrupt routine - A PAU_TETRA project which only contains:
Is there any recommandations in order to use offset command in XC8 ? In attachment, you can see Jump_preject and PAU_TETRA project . I don't understand what is wrong. I will be very grateful if anyone could help me... Many thanks BR Olivier Attachment(s) Test_120318_2_forum.zip (328.15 KB) - downloaded 57 times |
我怀疑“Jippi项目”中断在“ASM GOTO”之前保存了很多上下文。因为你有两个C项目,RAM重叠,所以坏事情发生了。你可以试着用MCC生成一个引导加载程序,看看它是如何处理中断的,或者让“JunpIpType”成为一个简单的汇编程序而不是C。
以上来自于百度翻译 以下为原文 I suspect the "jump_project" interrupt is saving a lot of context before the "asm goto". Since you have two C projects, the ram overlaps, so bad things happen. You might try generating a bootloader using MCC and see how it handles the interrupts. Or make "jump_project" a simple assembly program rather than C |
5060 浏览 9 评论
1945 浏览 8 评论
1879 浏览 10 评论
3100 浏览 3 评论
2174 浏览 5 评论
613浏览 1评论
484浏览 1评论
343浏览 1评论
515浏览 0评论
422浏览 0评论
GMT+8, 2024-9-20 12:36 , Processed in 1.010050 second(s), Total 44, Slave 39 queries .
