您好,我想用一个PIC32 MX575 F512L在现有项目中使用ICD4而不是ICD3。这个项目用ICD3调试没有问题。用ICD4,从“调试项目”图标开始,我在ICD4窗口中得到以下错误:PLAB ICD 4…当前加载版本:应用程序版本….01.02.16BooD版本…01.00 .00 FPGA版本….01.00 .00脚本版本….00 .02.23脚本构建号….45 A591CBC0应用程序构建号…012345 67 89-目标电压检测器DPAST设备PIC32 MX55F512L发现。设备ID修订= 0xA5Error…下面的内存区域将被编程:程序存储器:起始地址=0x1D08000,结束地址=0x1D08FFFAST内存:起始地址=0x1D9009000,结束地址=0x1D064 FFFFACtiON内存启动配置文件TreWreDebug向量用状态类型=RunScript失败,脚本名称=WrreDebug Gebug,状态=0x102。无法进入调试模式,因为编程调试信息失败。配置位的无效组合可能导致这个问题,如:是否可以用ICD3和ICD4调试相同的设置项目?
以上来自于百度翻译 以下为原文 Hello, I want to use the ICD4 instead of ICD3 in an existing project with a PIC32MX575F512L. The debugging of this project with ICD3 works without problems. With ICD4, after start with the "Debug Project" icon, I got the following error in the ICD4 window: ############################### Connecting to MPLAB ICD 4... Currently loaded versions: Application version............01.02.16 Boot version...................01.00.00 FPGA version...................01.00.00 Script version.................00.02.23 Script build number............45a591cbc0 Application build number.......0123456789 Target voltage detected Target device PIC32MX575F512L found. Device Id Revision = 0xA5 Erasing... The following memory area(s) will be programmed: program memory: start address = 0x1d008000, end address = 0x1d0087ff program memory: start address = 0x1d009000, end address = 0x1d064fff configuration memory boot config memory Script WriteDebugVector failed with status Type = runScript, Script name = WriteDebugVector, Status = 0x102 . Could not enter debug mode because programming the debug information failed. Invalid combinations of config bits may cause this problem ############################### Which config bits have to change ? Is it possible to debug the project with the same settings with ICD3 and ICD4 ? |
7个回答
可以使用IPE擦除所有断点集MPLABX,当从那里开始单步执行时,停止在主干上。
以上来自于百度翻译 以下为原文 maybe use IPE to erase chip remove all breakpoints set MplabX to stop at main when starting Single step from there |
你好,吉姆,我试过你的建议:用IPE V4.15擦除芯片-删除所有断点-当启动正常构建时,设置MPLABX停止在主服务器上运行,没有错误。尝试调试项目:再次在ICD4窗口中使用相同的错误消息:脚本Read Debug GraveAccess失败,状态类型=RunScript,脚本NAUM= WrreDebug Guffic,状态=0x102无法进入调试模式,因为编程调试信息失败。配置位的无效组合可能会导致这个问题,我也尝试“停止重置向量”,但同样的问题。
以上来自于百度翻译 以下为原文 Hello Jim, I tried your proposals: - erased chip with IPE v4.15 - removed all breakpoints - set MplabX to stop at main when starting - normal build runs without errors - try to debug project: again the same error message in ICD4 window: Script WriteDebugVector failed with status Type = runScript, Script name = WriteDebugVector, Status = 0x102 Could not enter debug mode because programming the debug information failed. Invalid combinations of config bits may cause this problem I tried also "halt at reset vector", but same problem. |
或者它可能不喜欢你的配置位。也许你可以试试默认设置。
以上来自于百度翻译 以下为原文 Or maybe it does not like your config bits. Maybe you could try with the defaults |
我也有同样的问题。PICTIT3工作良好,没有变化(除了插在PICTIT3中),这是一个麻烦。
以上来自于百度翻译 以下为原文 I"m having the same issue. picKit3 works fine with no changes (other than plugging in the picKit3,) which is a bummer. |
您好,如果您有PACTIT4问题,请将其报告给本页所示的邮件地址:http://Microchip .com /PACTIT4。固件不断升级,以增加对新设备的支持。为了请求优先设备支持或报告问题,电子邮件:CIPIT4AUPDATE@ MICCHIP.COMTO检查支持的设备:如果您安装了MPLAB X IDE,您可以浏览到MPLAB X安装目录下的“DOCS”文件夹,并打开文件“设备支持.HTM”。从这个链接:http://www. McCalp/com,MPLABX IDE发布说明。或者,你可以下载当时的MPLAB ICD 4在电路调试器/程序员中支持很多,但不是全部,PIC MCU和DSPIC DSC。固件不断升级,以增加对新设备的支持。为了请求优先设备支持或报告问题,电子邮件:ICD4U-UpDATE.MICCHIP.COM如果您安装了MPLAB X,您可以浏览到MPLABX安装目录下的“DOCS”文件夹,并打开文件“设备支持.HTM”。或者,您可以从这个链接下载:http://www. McCux.com /MPLABX IDE发布说明。
以上来自于百度翻译 以下为原文 Hi, If you have Pickit4 issues, report them to the mail addresse shown on this page : http://microchip.com/pickit4 ==================================================================== The MPLAB PICkit 4 In-Circuit Debugger/Programmer supports many, but not all, PIC MCUs and dsPIC DSCs at this time. The firmware is continually being upgraded to add support for new devices. To request priority device support or to report issues, email: PICkit4_Update@microchip.com To check supported devices: If you have MPLAB X IDE installed, you can browse to the “docs” folder under your MPLAB X installation directory and open the file “Device Support.htm”. Alternatively, you can download it from this link: http://www.microchip.com/mplabx-ide-release-notes ==================================================================== If you have ICD4 issues, report them to the mail addresse shown on this page : http://www.microchip.com/icd4 ==================================================================== The MPLAB ICD 4 In-Circuit Debugger/Programmer supports many, but not all, PIC MCUs and dsPIC DSCs at this time. The firmware is continually being upgraded to add support for new devices. To request priority device support or to report issues, email: ICD4_update@microchip.com If you have MPLAB X installed, you can browse to the “docs” folder under your MPLABX installation directory and open the file “Device Support.htm”. Alternatively, you can download it from this link: http://www.microchip.com/mplabx-ide-release-notes ==================================================================== |
5360 浏览 9 评论
2092 浏览 8 评论
1991 浏览 10 评论
3273 浏览 3 评论
2304 浏览 5 评论
869浏览 1评论
756浏览 1评论
699浏览 1评论
750浏览 0评论
644浏览 0评论
GMT+8, 2025-2-23 23:47 , Processed in 1.117483 second(s), Total 56, Slave 51 queries .
