嗨,所有,我试图执行JTAG指令与PIC32 MX100F016B微控制器。作为实验,我操作了不同频率的指令。我注意到,切换边界扫描链的指令(采样/预加载、ExtTest、高Z)只能从某个频率正常工作。在该频率以下,输出被设置为HYZ(包括TDO输出)。我发现在标准1149.1中没有迹象表明JTAG应该以一定的频率运行。有任何想法如何与这个芯片系列。亲切问候
以上来自于百度翻译 以下为原文 Hi all, I am trying to execute JTAG instructions with the PIC32MX100F016B microcontroller. As an experiment I have operated the instructions in different frequencies. I notice that the instructions that switch the Boundary Scan chain (Sample / Preload, Extest, High-Z) only work properly from a certain frequency. Below this frequency, the outputs are set to HighZ (including TDO output). I find in the standard 1149.1 no indication that JTAG should be operated with a certain frequency. Has any idea how it is with this chip series. with kind regards |
数据表指定TCK周期时间为25纳秒,所以您的最大速度应该是大约40兆赫。但是你也需要注意其他信号的设置和保持时间。
以上来自于百度翻译 以下为原文 The data sheet specifies a TCK cycle time of 25 ns, so your max speed should be around 40 MHz. But you may also need to pay attention to the setup and hold times for the other signals. |
谢谢你的回答,我的意思是反过来。我在静态频率下运行JTAG,所以频率很低。这意味着问题发生在某个较低的频率。
以上来自于百度翻译 以下为原文 Thanks for the answer. I mean it the other way round. I run the JTAG in static frequency, so low frequency. That means that the problem occurs at a certain lower frequency |
5317 浏览 9 评论
2072 浏览 8 评论
1977 浏览 10 评论
3248 浏览 3 评论
2285 浏览 5 评论
831浏览 1评论
724浏览 1评论
670浏览 1评论
723浏览 0评论
619浏览 0评论
GMT+8, 2025-2-1 01:40 , Processed in 1.330881 second(s), Total 79, Slave 63 queries .
