嗨,我想用一个CGG2芯片设计一个USB -C-PD电源,并有以下问题:
1、在我的设计中,我只需要CGX芯片来处理USB -C-PD消息。ccg2芯片能胜任这项工作吗? 2 /固件映像是由CyPress提供的,但不是源代码,这意味着我不能也不需要了解固件的内部结构。我假设固件包括为我配置PD参数的用户界面,这就是我所需要的。我说的对吗? 这些是我在CGX解决方案之前需要进一步回答的两个基本问题。非常感谢! 弗兰西斯 以上来自于百度翻译 以下为原文 Hi, I am thinking of using a CCG2 chip in the design of an USB-C PD power source, and have the following questions: 1/ in my design, I only need the CCGx chip to handle the USB-C PD messaging. Is the CCG2 chip sufficient to do the job? 2/ The firmware image is provided by Cypress but not the source code, it means I cannot nor do I need to understand the internals of the firmware. I am assuming that the firmware includes the user interface for me to configure the PD parameters, and that’s all I need. Am I right? These are the two essential questions that I need answered before I pursue any further on the CCGx solution. Thank you very much! Francis |
***4 发表于 2018-10-25 16:02 嗨,莉莎, 非常感谢你的回复。我将遵循您发送给我的链接,为进一步研究CGX解决方案。 真诚地, 弗兰西斯 以上来自于百度翻译 以下为原文 Hi Liza, Thank you very much for your reply. I shall follow the links that you sent me for further study of the CCGX solutions. Sincerely, Francis |
775个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
3139 浏览 0 评论
2290 浏览 1 评论
2014 浏览 1 评论
3856 浏览 1 评论
1914 浏览 6 评论
3789浏览 2评论
2314浏览 2评论
578浏览 2评论
555浏览 2评论
4058浏览 2评论
GMT+8, 2025-7-6 05:34 , Processed in 0.982898 second(s), Total 49, Slave 42 queries .
