我使用的是NETX DIO BSD层API。
在手册中,我需要首先创建DNS客户端,以便使用GETADDRIMO。 但是,当我调用NXYDSNSUBLY时,应用程序就被冻结了。 我添加了EnabLeNxdBSDSOCKET,NXYBSDYNEABLE,DNS定义。 如果我有什么不对劲,请告诉我。 (或请分享,如果你有一个很好的例子来源。) 以上来自于百度翻译 以下为原文 I'm using the netx duo bsd layer APIs. In manual, i need to create dns client first for using getaddrfino. However, when i call nx_dns_create, then application freezed. I added ENABLE_NXD_BSD_SOCKET, NX_BSD_ENABLE_DNS definitions. Please let me know if I have something wrong. (or Please share, if you have a good example source.) |
DNS的WAPI API可以在43xxxWi-Fi/Loope/DaimON/DNSSReDeNe/DNSReReNo.h中找到。
你能让我们知道你为什么要使用NETX DO BSD层API吗?您试图编写的应用程序还必须包含生成过程中的NXDYBSD.C。该文件必须以与其他应用程序文件相同的方式编译,其对象窗体必须与应用程序的文件链接。但是NSDDBSD.C文件在SDK中没有真正暴露出来。 以上来自于百度翻译 以下为原文 The WICED APIs for DNS can be found at 43xxx_Wi-Fi/libraries/daemons/DNS_redirect/dns_redirect.h. Could you please let us know why you are trying to use NetX Duo bsd layer APIs? The application that you are trying to write must also include nxd_bsd.c in the build process. This file must be compiled in the same manner as other application files and its object form must be linked along with the files of the application. But nxd_bsd.c file is not really exposed in SDK. |
757个成员聚集在这个小组
加入小组2137 浏览 1 评论
1877 浏览 1 评论
3700 浏览 1 评论
1815 浏览 6 评论
1561 浏览 1 评论
756浏览 2评论
509浏览 2评论
470浏览 2评论
422浏览 2评论
1113浏览 2评论
GMT+8, 2025-2-2 14:37 , Processed in 0.870291 second(s), Total 75, Slave 59 queries .
