电子发烧友论坛|
在UM1052中(STM32F0x / F100xx / F103xx / F2xx / F30x / F4xx
PMSM单/双FOC SDK v3.4)它写成: ''电机控制软件开发套件(STSW-STM32100) 设计用于STM32F0x / F100xx / F103xx,STM32F2xx, STM32F302xB / C,STM32F303xB / C和F4xx微控制器。软件库 实现三相永磁体的磁场定向控制(FOC)驱动 同步电动机(PMSM),表面安装(SM-PMSM)和内部(I-PMSM)。 描述了配备有编码器或转速计发生器的AC感应电动机的控制 在UM0483用户手册中。 但是看看UM0483(STM32F103xx 交流感应电机IFOC软件库V1.0)我发现这个pdf使用的是与UM1052中使用的库不同的库。 我只从ST.com STM32 PMSM FOC LIB v3.4 WEB下载;它具有与UM0483中描述的文件夹结构不同的文件夹结构。 我搜索了STM32 FOC Firmware Libraries v1.0,它有ACIM控制方法但是徒劳无功。 有人能告诉我固件标题''STM32 PMSM FOC LIB v3.4 WEB'是否可以控制ACIM电机? 其他库''STM32F103xx交流感应电机IFOC软件库V2.0'在哪里? 同样的UM1052说我可以在st.com上找到它,但我找不到它。 以上来自于谷歌翻译 以下为原文 In UM1052(STM32F0x/F100xx/F103xx/F2xx/F30x/F4xx PMSM single/dual FOC SDK v3.4) it is written: ''Motor Control Software Development Kit (STSW-STM32100) designed for and to be used with STM32F0x/F100xx/F103xx, STM32F2xx, STM32F302xB/C, STM32F303xB/C and F4xx microcontrollers.The software library implements the Field Oriented Control (FOC) drive of 3-phase Permanent Magnet Synchronous Motors (PMSM), both Surface Mounted (SM-PMSM) and Internal (I-PMSM). The control of an AC induction motor equipped with encoder or tacho generator is described in the UM0483 user manual. But looking in UM0483 (STM32F103xx AC induction motor IFOCsoftware library V1.0) I have discovered that this pdf uses a different library from the one used in UM1052. I have only downloaded from ST.com STM32 PMSM FOC LIB v3.4 WEB ; which has a folder structure different form the one described in UM0483 . I searched for STM32 FOC Firmware Libraries v1.0 which has ACIM control methods but in vain . Can someone tell me if the firmware intitled ''STM32 PMSM FOC LIB v3.4 WEB '' can controll ACIM motors? And where is the other library ''STM32F103xx AC induction motor IFOC software library V2.0 '' ??? The same UM1052 says I can find it on st.com, but I can't find it. |
3个回答
Ciao ionut.fasoola
名称中所述的STM32 PMSM FOC Lib仅为永磁电机(PMSM =永久磁铁同步电机)。 不幸的是,STM32F103xx交流感应电机IFOC软件库V2.0已经不在网络中,因此如果您需要,您必须直接向最近的ST本地支持人员询问。 感谢您的报告,现在文档已更新。 再见 梁咏琪 以上来自于谷歌翻译 以下为原文 Ciao ionut.fasoola The STM32 PMSM FOC Lib as stated in the name is only of permanet magnet motor (PMSM = pemanent magnet syncronous motors). Unfortunately the STM32F103xx AC induction motor IFOC software library V2.0 is no more in the web so if you require it you have to ask directly to your nearest ST local support. Thank you for your report, now the documentation has been updated. Ciao Gigi |
谢谢你的回复,吉吉
另一个问题:是否有使用STM32的交流感应电机控制库? 最好的祝福 以上来自于谷歌翻译 以下为原文 Thanks for your reply,Gigi Another question : is there a library for AC induction motors control using STM32? Best regards |
Ciao ionut.fasoola
目前唯一的FW是STM32F103xx交流感应电机IFOC软件库V2.0,如上所述,您必须直接向最近的ST本地支持人员询问。 再见 以上来自于谷歌翻译 以下为原文 Ciao ionut.fasoola At the moment the only FW is the STM32F103xx AC induction motor IFOC software library V2.0 and as discussed you have to ask directly to your nearest ST local support. Ciao |
2754 浏览 1 评论
3246 浏览 1 评论
1817 浏览 1 评论
3657 浏览 6 评论
6048 浏览 21 评论
1345浏览 4评论
204浏览 3评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
360浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
453浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
278浏览 2评论
GMT+8, 2024-12-31 06:27 , Processed in 0.976260 second(s), Total 48, Slave 43 queries .
