如何在Linux / Android系统中集成ST s压力传感器和湿度传感器?
#压力湿度传感器 以上来自于谷歌翻译 以下为原文 how to integrate ST�s pressure sensors and humidity sensors in Linux/Android systems? #pressure-humidity-sensors |
你好,
应用笔记AN4503解释了如何将STMicroelectronics环境传感器集成到Linux / Android系统中。它提供了有关如何管理此任务的详细信息和过程。 还讨论了传感器HAL(硬件抽象层)的配置文件以及成功集成不同类型传感器的问题和可能的解决方案。 最后,还描述了该库的构建和安装。 http://www.st.com/web/en/resource/technical/document/application_note/DM00118439.pdf 最好的祝福 以上来自于谷歌翻译 以下为原文 Hello, The application note AN4503 explains how to integrate the STMicroelectronics environmental sensor in Linux/Android systems. It provides detailed information and procedures on how to manage this task. The configuration files of the sensor HAL (hardware abstraction layer) are also discussed along with the issues and possible solutions for successfully integrating different kinds of sensors. Finally, the building and installation of this library is also described. http://www.st.com/web/en/resource/technical/document/application_note/DM00118439.pdf Best Regards |
2411 浏览 1 评论
3127 浏览 1 评论
1698 浏览 1 评论
3510 浏览 6 评论
5865 浏览 21 评论
854浏览 4评论
1229浏览 4评论
在Linux上安装Atollic TRUEStudio的步骤有哪些呢?
495浏览 3评论
使用DMA激活某些外设会以导致外设无法工作的方式生成代码是怎么回事
1211浏览 3评论
1265浏览 3评论
GMT+8, 2024-9-20 12:37 , Processed in 1.471368 second(s), Total 76, Slave 60 queries .
