嗨,
可以安装在具有8个RAM模块16 Gb的S2600CP上。 金士顿KVR16R11D4 / 16(1600MHz,ECC,CL11,1.5V)其他8个模块KVR16LR11D4 / 16(1600MHz,ECC,CL11,1.35V)? 是否支持相同类型但具有不同电压的RAM混合? 谢谢回复 以上来自于谷歌翻译 以下为原文 Hi, is possible to install on an S2600CP that has 8 RAM modules 16 Gb. Kingston KVR16R11D4/16 (1600MHz, ECC, CL11, 1.5V) other 8 modules KVR16LR11D4/16 (1600MHz, ECC, CL11, 1.35V)? Is the mix of RAM of the same type but with different voltage supported? Thanks for the reply |
您好MaxUS,您已请求的英特尔®服务器主板S2600CP的交互式威廉希尔官方网站
支持已停止。
我们可以通过我们的网站为您提供资源和自助服务支持信息。 我们强烈建议您从产品支持站点获取信息,并且所有可用的威廉希尔官方网站 信息都包含在支持站点上。此外,处理器插槽内或跨处理器插槽不支持将低压(1.35V)DIMM与标准电压(1.5V)DIMM混合使用 。您可以通过查看英特尔®服务器主板S2600CP的威廉希尔官方网站 产品规格(第36页)来确认此信息。我将继续将您的主题移至停产产品社区,以便您可以从社区其他成员那里获得建议。最好的问候, 塞尔吉奥·S 以上来自于谷歌翻译 以下为原文 Hello MaxUS, The interactive technical support for the Intel® Server Board S2600CP you have requested has been discontinued. We can provide you with resources and self-service support information through our website. We highly suggest that you get information from the product support site and all available technical information is included on the support site. Additionally, mixing Low Voltage (1.35V) DIMMs with Standard Voltage (1.5V) DIMMs is not supported within or across processor sockets. You can confirm this information by checking the Technical Product Specification for Intel® Server Board S2600CP, page 36. I am going to proceed and move your thread to the Discontinued Products Community, so you can get recommendations from fellow community members. Best regards, Sergio S. |
371浏览 0评论
GMT+8, 2024-9-22 21:13 , Processed in 0.703024 second(s), Total 77, Slave 61 queries .
