你好,
我们正在开发9轴传感器:LSM9DS0,它通过I2C接口与MCU连接。请查看随附的电路图供您参考。 此外,我们已经使用评估板(STEVAL-MKI154V1)进行了检查,然后它可以与我们定制的板载控制器一起工作,但是我们的板载LSM9DS0传感器没有给出确认。我们注意到C1_XM& SETC_XM,SETP_XM。这里我们使用下面的从I2C地址: 加速度计地址 - 0x3C 陀螺仪地址 - 0xD4 我们已经完成了以下方法,但没有得到任何确认。 1.将拉电阻从10K改为4.7K / 2.2K 2.断开VDD_IO与VDD的连接 3.我们观察到I2C波形(I2C地址)正常,但确认除外。 请给我们澄清一下VDD_IO引脚是否该引脚用作NC(不连接)或连接到VDD? 在这种情况下任何帮助将不胜感激。 谢谢 Bhavin 以上来自于谷歌翻译 以下为原文 Hello, We are working on 9 Axis Sensor : LSM9DS0 which is interfaced with MCU over I2C interface. Please find the attached circuit diagram for your reference. Also, We have checked using evaluation board (STEVAL-MKI154V1) then it works fine with our customized on board controller, but our on board LSM9DS0 sensor not given acknowledgment. We have noticed not getting voltage on C1_XM & SETC_XM , SETP_XM. Here we are using the below slave I2C address: Accelerometer address - 0x3C Gyroscope address - 0xD4 We have done below approaches but not getting any acknowledgement. 1. Change pull resistor from 10K to 4.7K / 2.2K 2. Remove connection of VDD_IO from VDD 3. We have observed I2C waveform (I2C Address) is OK except acknowledgement. please give us clarification for VDD_IO pin is this pin is used as NC(not connect) or connected to VDD? Any help in this case will be appreciated. Thank You Bhavin |
你好,
在原理图中,我可以看到I2C SDA和SCL线路是交换的。它可能是您的I2C问题的根源。 关于VDD_IO,它是I / O线的模块电源,如果要与设备通信,则必须连接到电源。它可以连接到VDD。 最好的祝福, 玛丽安 以上来自于谷歌翻译 以下为原文 Hello, In schematic I can see that I2C SDA and SCL lines are swapped. It could be the source of your problems with I2C. Regarding VDD_IO, it is module power supply for I/O lines, it must be connected to power supply if you want to communicate with device. It could be connected to VDD. Best Regards, Marian |
2827 浏览 1 评论
3267 浏览 1 评论
1844 浏览 1 评论
3693 浏览 6 评论
6098 浏览 21 评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
395浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
487浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
316浏览 2评论
使用STM32F407VET6的USB2.0功能,发现ctl后芯片无数据返回,是什么原因可能导致的呢?
232浏览 2评论
用STM32G431开发工程,1.50版本的Package包文件无法输出项目工程
339浏览 2评论
GMT+8, 2025-2-3 01:08 , Processed in 0.794564 second(s), Total 44, Slave 37 queries .
