我不能在网上看视频,我在哪里可以找到一些基本的文件来帮助我开始?我想学习PIC8BIT包括硬和软。
以上来自于百度翻译 以下为原文 I cannot watch the video on the web ,and where i can find some basic document to help me start ? I want to learn the PIC8bit included the hard and soft . |
9个回答
嗨,当原来的海报说他看不到视频,那就没有帮助他看视频了!KATELA编写或维护的网站有8位PIC微控制器的文本和代码教程,只需跳过视频,试着忽略广告。它们太多了,涵盖了很多高级主题,很难找到开始的地方。您可以从http://www-SuothOrth.C.Z/PixtoMigCHIP-XC8编译器/然后:http://www-Suthoals.Co ZA/连接-光发射-dioDES-DE-DE-PIC-微控制器XC8/和:http://www-SuthOrth.Co ZA/Read Swit-Swit-PIC-微控制器XC8/……在教程中,您应该查看PIC16设备的数据表,或者在使用MPLAX时,在安装XC8编译器时,也有文件和帮助文件HTTPS://www. MyCHIP.COM/MPLAB/MPLAB-X-IDE,HTXPS://www. McCHIP.COM/MPLAB/编译器也有XC8C COMP。同时,您还可以安装MPLAB X和XC8编译器,并在MPLAB的模拟器中运行代码,也有MPLAB XPRESHTTPS://www. MyCHIP.COM/MPLAB/MPLAB-XPR。ESS,可以在本地计算机上安装任何东西。向下查找:在MPLAB XPress MysIL中使用8位MCU启动
以上来自于百度翻译 以下为原文 Hi, When the Original Poster state that he cannot watch video, then there is no help telling him to watch video! The website written or maintained by katela have a number of text and code tutorials for 8-bit PIC microcontrollers, just skip the videos and try to ignore advertising. They are so many, and cover so many advanced topics that it may be difficult to find where to begin! You may start with: https://www.studentcompanion.co.za/introduction-to-microchip-xc8-compiler/ then: https://www.studentcompanion.co.za/connecting-light-emitting-diodes-led-to-a-pic-microcontroller-xc8/ and: https://www.studentcompanion.co.za/reading-switches-with-pic-microcontroller-xc8/ ... In addition to Tutorials, you should look at Datasheet for the PIC16 device you have, or want to use. When MPLAB X is installed, there is also documentation and help files https://www.microchip.com/mplab/mplab-x-ide When XC8 compiler is installed, https://www.microchip.com/mplab/compilers there is also XC8 C Compiler Users Guide and more, in a documentation directory together with the compiler program. Even if you do not have hardware yet, then you may still install MPLAB X and XC8 compiler, and run code in the Simulator that is part of MPLAB. There is also MPLAB Xpress https://www.microchip.com/mplab/mplab-xpress which may be used without installing anything on the local computer. Look down and find: Getting Started using 8-bit MCUs in MPLAB Xpress Mysil |
我想了解更多有关你的情况,然后推荐一些东西。你是学生吗?工作工程师还是程序员?你以前有过微控制器的经验吗?你有哪些编程语言?你能访问像微芯片开发板那样的硬件吗?你有预算得到一个吗?你的学习风格是什么?在做某事之前,你更喜欢做一个学习型的人或是更好地为你的书学习工作吗?你希望你的计划做什么?这些问题的答案可以帮助我们提供更具体的答案来帮助你。Microchip提供了许多可自由下载的工具,但它们对启动的人来说是压倒性的。
以上来自于百度翻译 以下为原文 I would like to know more about your situation before recommending something.
你在回答谁?你似乎忽略了在你之前的所有问题。
以上来自于百度翻译 以下为原文 Who are you answering? You seem to have ignored all the queries in the post immediately before yours. |
我的主要是机械设计,我想做一些汽车,所以我想学习一些关于PIC,上面的网页我找到一些基本的东西,我会从它开始,它是有用的。
以上来自于百度翻译 以下为原文 My main is mechanical design and i want to do something automotive ,thus i want to learn some about the PIC, the above web i find some thing basic and l will start with it , it is useful. |
我建议您得到一个原型板,例如Explorer 16,它可以有许多不同类型的MCU插在它上面。这样你就可以从一个较小的MCU开始,在你的技能水平提高的时候,你可以使用更多的有能力的MCU。使用这样的一个板也能解决最初的“硬件”问题,所以你可以直接编程。当你处于学习阶段时,你也可以很容易地将各种外围设备添加到电路板上。一旦你对硬件和开发环境有了一点信心,那么你就可以开始考虑你自己的硬件设计了。安
以上来自于百度翻译 以下为原文 I would recommend that you get a prototyping board such as the Explorer 16 which can have a number of different types of MCUs plugged in to it. That way you can start with a smaller MCU and work up to more capable ones as your skill level increases. Using such a board will also solve the initial 'hardware' problem for you so you have something to program straight way. You can also add various peripheral devices fairly easily to the board while you are in the learning phase. Once you feel a bit more confident with the hardware and the development environment, then you can begin to think about your own hardware design when you settle on an initial project to do. Susan |
5362 浏览 9 评论
2093 浏览 8 评论
1995 浏览 10 评论
3274 浏览 3 评论
2306 浏览 5 评论
870浏览 1评论
758浏览 1评论
699浏览 1评论
750浏览 0评论
644浏览 0评论
GMT+8, 2025-2-24 19:29 , Processed in 1.390586 second(s), Total 63, Slave 56 queries .
