扫一扫,分享给好友
大家好,
我想知道SID的定义在哪里?我试图找出最大的电流缓冲输出的DAC。到目前为止,我有SID 275(10毫安)和SID 278(4毫安)。 以上来自于百度翻译 以下为原文 Hello all, I was wondering where the definition for the SIDs are located? I am trying to find out the max current for the buffered output of the DAC. So far, I have SID 275 (10 mA) and SID 278 (4 mA). |
它看起来像两个规格ID,SID265和SID27 8是相同的规格与不同的值,但它们不是。SID255是一个2.7伏特以上的VDDA的驱动电流。SID27是1.7伏特的VDDA驱动电流,小于2.7伏特。
我会跟店主谈谈,并让他把这张条子的细节/条件栏列出来。很抱歉弄乱了。 作记号 以上来自于百度翻译 以下为原文 It does look like the two Spec IDs, SID275 and SID278 are the same spec with different values, but they are not. SID275 is the drive current for a Vdda of 2.7 volts and above. SID278 is the drive current for Vdda of 1.7 volts to less than 2.7 volts. I will talk to the owner of the specification and have him put that note is the Details/Conditions column to make it clear. Sorry for the confusion. Mark |
754个成员聚集在这个小组
加入小组2110 浏览 1 评论
1858 浏览 1 评论
3673 浏览 1 评论
1791 浏览 6 评论
1540 浏览 1 评论
575浏览 2评论
428浏览 2评论
440浏览 2评论
390浏览 2评论
922浏览 2评论
GMT+8, 2024-12-27 02:10 , Processed in 0.824572 second(s), Total 78, Slave 62 queries .
