扫一扫,分享给好友
你好,我想问社区成员,如果他们有任何经验,使用CYC68013A EZ-USB FX2LP USB微控制器来编程PSoC5?我正在查看PSoC5开发工具包的原理图,他们用这个设备连接到一个迷你USB连接器,然后你可以编程PSoC5。我想知道这是否是一个直接编程PSOC5的方法,如果使用这个USB微控制器有什么问题?
请分享您的意见。 谢谢, 乔 以上来自于百度翻译 以下为原文 Hello, I wanted to ask the community members if they had any experience using the CYC68013A EZ-USB FX2LP USB Microcontroller to program the PSoc5? I was looking over the schematics for the PSoc5 Development kit and they use this device to connect to a mini-USB connector which you can then program the PSoc5. I want to know if this is a straight forward approach to program the PSoc5 and if there were any problems using this USB microcontroller? Please share any comments you may have. Thanks, Joe |
我进一步查看PSoC 5 DEV工具包原理图,我注意到U3是EEPROM,我开始认为这是来自柏树的自定义代码,如果这是真的,那么这就改变了一切。
以上来自于百度翻译 以下为原文 I was further looking at the Psoc 5 Dev Kit schematics and I noticed U3 which is a EEPROM, I'm starting to think that this is custom code from Cypress and if that is true then this changes everything. |
lingjianghui 发表于 2018-10-23 08:53 如我所记得的,FeleSoC板使用FX2芯片。你可以在这里找到FieloSc的原理图和电路板布局。 GithuB-FRIESOC/FRIESOC:FRIESOC板布局和示意图 FieSoC和FieloSoc迷你乔恩默勒- Kickstarter 我还会检查一个FieloC2的原理图。 FeleSoC2开发板-PSoC5LP—DEV-13229 -斯帕克菲电子 ODISSEY1 以上来自于百度翻译 以下为原文 As I recollect, the FreeSoC board used FX2 chip. You can find FreeSoc schematic and board layout here GitHub - freesoc/freesoc: freeSoC Board Layouts and Schematics freeSoC and freeSoC Mini by Jon Moeller — Kickstarter I would also check a FreeSoC2 schematics FreeSoC2 Development Board - PSoC5LP - DEV-13229 - SparkFun Electronics /odissey1 |
741个成员聚集在这个小组
加入小组2002 浏览 1 评论
1761 浏览 1 评论
3545 浏览 1 评论
1696 浏览 6 评论
1466 浏览 1 评论
273浏览 2评论
170浏览 2评论
355浏览 2评论
299浏览 2评论
487浏览 2评论
GMT+8, 2024-9-20 17:49 , Processed in 0.651245 second(s), Total 45, Slave 40 queries .
