亲爱的各位
我将使用CYBT-34 3026-01模式开发BT/BLE与平板通信的HF阅读器。 HF领导者有一个说话人可以减少采摘错误。 如果平板电脑通过BT将声音效果(wav格式,8bit,440Hz)传送到HF阅读器, 我想知道WHER平板可以同时接收BT或HF读写器的HF标签信息(100字节)。 谢谢, 最好的问候。 以上来自于百度翻译 以下为原文 Dear all I will use CYBT-343026-01 modle to develop HF reader that communicate to tablet by BT/BLE. HF leader have a speaker to worker reduce picking mistakes. If the tablet is transmiting sounds effect (WAV format, 8bit, 44100Hz) to HF reader by BT, I'd like to know wether tablet can recieve HF tag information ( 100Byte ) by BT or BLE from HF reader concurrently. Thanks, Best regards. |
3个回答
嗨,Takujji Naoyama san,
是的,可以同时从平板传送到HF阅读器的音频和从HF阅读器到平板电脑的标签信息。 当你说HF时,你指的是免提吗? -您希望如何发送HF标签信息?过度?CYBT-33026支持同时BT和BLE连接,因此您可以做到这一点。 以上来自于百度翻译 以下为原文 Hi Takujji Naoyama-san, Yes, it is possible to transmit audio from tablet to HF reader and tag information from HF reader to tablet at the same time. - When you say HF, are you referring to Handsfree? - How do you wish to transmit HF tag information? Over BLE? CYBT-343026 supports simultaneous BT and BLE connections, so you can do that. |
烈阳异丙醇 发表于 2018-10-23 06:33 亲爱的YSU 谢谢你的回复。 高频阅读器是一种高性能RFID标签阅读器。 我认为在附图中显示标签信息是很好的。 如果有声音效果,播放时间太长, 沟通没有问题吗? 谢谢, 最好的问候。 YSUS.Y.Y.S. 嗨,Takujji Naoyama san, 是的,它是可能的传输音频从平板从高频读写器的高频读取器和标签信息片同时。 当你说HF时,你指的是免提吗? -您希望如何发送HF标签信息?过度?cybt-343026同时支持BT BLE连接,所以你可以这样做。 以上来自于百度翻译 以下为原文 Dear yssu Thanks for the reply. HF reader is High Frecuency RFID Tag reader. I think it is good to transfer tag information by BE shown in attached picture. If there is the sounds effect that playing time is too long, is the communication no problem ? Thanks, Best regards. yssu による書き込み: |
如果存在同时激活的BT和BLE连接,那么无线电将在两个之间共享。所以,如果你有音频传输,并且想通过BLE传输一些数据,那肯定是“可能的”。然而,潜伏期将增加,并可能有一个小口吃的音频。 以上来自于百度翻译 以下为原文 If there is an simultaneous active BT and BLE connection, then the radio will be time shared between the two. So, if you have audio transfer going on and want to transmit some data over BLE, it is definitely 'possible'. However, the latency will increase and there might be a small stutter in the audio. |
759个成员聚集在这个小组
加入小组2151 浏览 1 评论
1897 浏览 1 评论
3718 浏览 1 评论
1828 浏览 6 评论
1574 浏览 1 评论
778浏览 2评论
534浏览 2评论
482浏览 2评论
443浏览 2评论
1138浏览 2评论
GMT+8, 2025-2-23 11:47 , Processed in 1.228013 second(s), Total 46, Slave 41 queries .
