嗨,大家好,
我的印象是Xilinx ISE软件的质量越来越差。 ISE 14.7 Bitgen中存在一个错误:将SPI选项切换到x4会导致将额外的多引导头插入Spartan 6比特流。 这意味着没有办法使用SPI x4并在没有此标头的情况下生成比特流。 在这个论坛上已经在ISE 13.3中报告了这个错误,从那时起没有任何反应。 你知道这个问题的解决方法吗? 问候 WOJTEK 以上来自于谷歌翻译 以下为原文 Hi guys, I have an impression that the quality of the Xilinx ISE software is worse and worse. There is a bug in ISE 14.7 Bitgen: switching SPI option to x4 causes the insertion of the additional multiboot header into Spartan 6 bitstream. It means that there is no way to use SPI x4 and to generate bitstream without this header. This bug was reported already in ISE 13.3 on this forum and no reaction since this time. Do you know any workaround of this problem? Regards Wojtek |
6个回答
ISE 14.7是ISE的最后一个版本。
如果你想要14.7固定的东西你需要打开一个webcase,准备提供一个测试用例并让你的FAE发起一个战术补丁请求。 该论坛不涉及bitgen,因为它被认为是配置工具而不是实现工具。 我认为“其他工具”论坛是可以讨论配置工具的地方。 以上来自于谷歌翻译 以下为原文 ISE 14.7 is the last ISE release. If you want something in 14.7 fixed you will need to open a webcase, be prepared to supply a test case and have your FAE initiate a tactical patch request. This forum does not cover bitgen as that is considered a configuration tools rather than an implementation tool. I think the "Other tools" forum is place where configuration tools can be discussed. |
bwade写道:
ISE 14.7是ISE的最后一个版本。 它不打算在Vivado支持Spartan-6,不是吗? 以上来自于谷歌翻译 以下为原文 bwade wrote:It's not planned to support Spartan-6 in Vivado, isn't it? |
VIVADO仅支持7系列和更高版本的设备
-------------------------------------------------- ----------------------------别忘了回复,给予kudo并接受为解决方案--------- -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 VIVADO only supports 7-series and later devices------------------------------------------------------------------------------ Don't forget to reply, give kudo and accept as solution ------------------------------------------------------------------------------ |
这是http://forums.xilinx.com/t5/Design-Tools-Others/Bug-in-Bitgen-SPI-x4-causes-that-the-multiboot-header-is/mp/379007#的复制主题
M5067。 -------------------------------------------------- ---------------------------------------------请将帖子标记为 如果提供的信息能够回答您的问题/解决您的问题,请“接受为解决方案”。给予您认为有用的帖子。 以上来自于谷歌翻译 以下为原文 This is a duplicate thread of http://forums.xilinx.com/t5/Design-Tools-Others/Bug-in-Bitgen-SPI-x4-causes-that-the-multiboot-header-is/m-p/379007#M5067 .----------------------------------------------------------------------------------------------- Please mark the post as "Accept as solution" if the information provided answers your query/resolves your issue. Give Kudos to a post which you think is helpful. |
venkata写道:VIVADO只支持7系列和更高版本的设备
那么我所遇到的问题是 - 当我们的设计工具被** ble **时,非7系列用户应该做什么? 如果家庭中最小的成员实际可以购买,我们会考虑新系列。 ----------------------------是的,我这样做是为了谋生。 以上来自于谷歌翻译 以下为原文 venkata wrote:So the question wojtek and I have, then, is -- what are non-Series 7 users supposed to do when our design tools are **bleep**canned? We'd consider the new series if the smallest members of the family were actually available for purchase. ----------------------------Yes, I do this for a living. |
只要没有任何新的开发计划,ISE将继续得到支持。
情况类似于在ISE 10.1之后从ISE中删除一些旧架构的情况,我们继续为这些用户支持10.1。 如果符合必要条件的ISE 14.7问题,仍然可以为关键问题创建补丁。 我个人处理实施工具的所有此类升级。 我不会再对这个Bitgen问题发表评论,因为它不在我的产品领域,我对这个主题一无所知。 以上来自于谷歌翻译 以下为原文 ISE will continue to be supported there just isn't any new development planned. The situation is similar to how some of the older architectures were dropped from ISE after ISE 10.1 and we continued to support 10.1 for those users. Patches can still be created for critical issues ISE 14.7 issues if they meet the necessary criteria. I personnaly handle all such escalations for the implementation tools. I won't comment any further on this Bitgen issue as it's not in my product area and I know nothing about the subject. |
2487 浏览 7 评论
2865 浏览 4 评论
2324 浏览 9 评论
3414 浏览 0 评论
2506 浏览 15 评论
2308浏览 1评论
649浏览 1评论
514浏览 1评论
2061浏览 0评论
790浏览 0评论
GMT+8, 2025-2-11 16:46 , Processed in 1.370874 second(s), Total 86, Slave 70 queries .
