我最近买了一台Gigabyte AORUS Z370 ULTRA GAMING 2.0 ATX主板,预装了32GB Intel Optane Memory。
起初我试图让我的ssd驱动器已安装Windows 10,它没有任何。 我没有在SSD末端的未分配空间,我只能在驱动器中间取消分配空间。 因此,按照一步一步的视频创建一个内置optane驱动程序的Windows安装程序。一切顺利,optane配置为BIOS,安装Windows没有问题,安装了英特尔optane软件,检测并配置驱动器与我的工作 启动驱动器。 然后我安装了所有其他驱动程序和任何更新。 然后我将我的主板BIOS更新为最新版本,然后再次启动到Windows。 在启动过程中,在登录屏幕之前在屏幕上瞥见一条消息。 我不知道它说了什么,它来了,快去读。 然后我登录到Windows并且optane内存软件提出了一条消息,说“您的系统不支持Intel optane - 未满足以下要求:X没有用于Intel Optane™内存的兼容磁盘.. Windows设备管理器具有:Intel (R)Chooser SATA / PCIe RST Premium控制器作为存储控制器,没有其他..此外,安装窗口和配置optane驱动器工作后安装的所有东西都不再安装。 在设置optane驱动器后不久,Windows记录的最后一件事是Windows更新。 所有驱动程序,软件和下载都消失了。 无论如何,我现在找不到或得到optane在Windows工作。 如果我在BIOS中禁用optane并尝试使用普通的SATA控制器启动,Windows将无法启动(BSoD)......这是可修复的,还是我将不得不再花5到6个小时观看该视频,进行另一个自定义 使用optane驱动程序启动USB磁盘和自定义Windows 10安装程序,然后重新安装所有内容? 以上来自于谷歌翻译 以下为原文 I recently bought a Gigabyte AORUS Z370 ULTRA GAMING 2.0 ATX Motherboard with 32GB Intel Optane Memory pre-installed. At first i tried to get my ssd drive with windows 10 already installed and it wasn't having any of it. I didn't have the unallocated space at the end of the SSD, and I could only unallocate space in the middle of the drive. So after following the step by step video to create a windows installer with optane drivers built in. Everything went fine, optane was configured in bios, windows installed with no issues and the Intel optane software installed, detected and configured the drive to work with my boot drive. I then installed all other drivers and any updates. I then updated my motherboards bios to the lastest version and then booted up into windows again. During the boot a glimpsed a message on their screen right before the login screen. I don't know what it said, it came and went to fast to read. I then signed in to windows and the optane memory software came up with a message saying 'Your system is not Intel optane ready - the following requirements were not met: X No compatible disks for Intel Optane ™ memory .. windows device manager has: Intel(R) Chooser SATA/PCIe RST Premium Controller as the storage controller, nothing else.. Also, everything installed after installing windows and configuring optane drive to work, wasn't installed anymore. The last thing windows logged was a windows update not long after setting up the optane drive. All drivers, software and downloads were gone. Anyway, I now can't find or get optane to work in windows. And if I disable optane in bios and try booting with normal SATA controllers, windows won't boot (BSoD)... Is this fixable, or am I going to have to spend another 5 - 6 hours watching that video, making another custom bootable u*** disk and custom windows 10 installer with optane drivers, and then reinstalling everything again? |
6个回答
Hello Hipster1966,感谢您联系英特尔®威廉希尔官方网站
支持。据我们了解,您需要有关英特尔®Optane™内存系列的帮助如果我们正确推断,开始诊断和随后的故障排除可能需要我们解决问题,我们将不胜感激
如果可以,请回复此帖子,如果您能够访问操作系统,请使用以下重要的基本信息: SSU登录.1-转到https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility?v=t下载软件.2-下载完成后,打开它.3- 标记“Everything”框,然后单击“Scan.4-完成扫描后,单击”下一步。“5-单击”保存“.6-将文件附加到您的回复。窗口”磁盘管理“的屏幕截图 显示所有硬盘和分区。如果您无法访问您的操作系统,我们建议您重新安装操作系统并遵循“英特尔®Optane™内存安装指南”和您的制造商手册。我们期待您的 回复。最好的问候,Josh B.Intel客户支持威廉希尔官方网站 人员与英特尔公司的合同 以上来自于谷歌翻译 以下为原文 Hello Hipster1966, Thank you for contacting Intel® Technical Support. As we understand, you need assistance with your Intel® Optane™ Memory Series If we infer correctly, to begin diagnosis and consequent troubleshooting that could take us to a resolution, and we would appreciate if you could, please, reply to this post with the following, important, basic information if you are able to access to the operating system:
1- Go to https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility?v=t and download the software. 2- When finished downloading it, open it. 3- Mark the box "Everything" and then click "Scan. 4- When finish scanning, click "Next." 5- Click on "Save." 6- Attach the file to your reply.
If you are not able to access your OS we recommend you to reinstall your operating system and to follow the “Installation Guide for Intel® Optane™ Memory” and your manufacturer manual. We will be looking forward to your reply. Best regards, Josh B. Intel Customer Support Technician Under Contract to Intel Corporation |
jerry1978 发表于 2018-10-23 18:16 感谢您的快速回复,我已附上报告和截图 Disk Manager.jpg 197.8 K. Report.txt.zip 20.3 K. 以上来自于谷歌翻译 以下为原文 Thank you for the rapid response, i have attached the report and screenshot
Hello Hipster1966,感谢您的回复和所提供的信息。基于您与我们分享的“Report.txt”日志文件,我们注意到您的BIOS模式设置为“传统模式”此模式不支持才能使用 Optane memory.We建议您按照OEM网站B-2部分提供的建议告诉我们结果。基于“磁盘管理器截图”,您提供了英特尔®Optane™内存系列(32GB,M.2 80mm) 您的操作系统甚至没有检测到PCIe 3.0,20nm,3D Xpoint作为存储设备。此问题可能与您当前的BIOS配置有关。我们建议您备份信息,更改BIOS设置并重新安装操作 系统按照“英特尔®Optane™内存安装指南”和您的制造商手册。我们希望您对此信息有所帮助。最好的问候,Josh B.Intel客户支持威廉希尔官方网站 人员与英特尔公司的合同 以上来自于谷歌翻译 以下为原文 Hello Hipster1966, Thank you for your reply and the information provided. Based on the “Report.txt” log file you shared with us we noticed that your BIOS mode is set in “Legacy mode" this mode is not supported in order to use the Optane memory. We advise you to follow the recommendation available in your OEM website section B-2 and let us know the results. Based in the “Disk Manager screenshot” you provided the Intel® Optane™ Memory Series (32GB, M.2 80mm PCIe 3.0, 20nm, 3D Xpoint) is not being detected even as a storage device by your OS. This issue can be related to your current BIOS configuration. We recommend you to back up your information, change your BIOS settings and to reinstall your operating system by to follow the “Installation Guide for Intel® Optane™ Memory” and your manufacturer manual. We hope you find this information helpful. Best regards, Josh B. Intel Customer Support Technician Under Contract to Intel Corporation |
jerry1978 发表于 2018-10-23 18:42 您好,再次感谢您的回复。 我想问一下,当你说我的BIOS模式设置为“Legacy mode”时。你的意思是Bios中的选项“使用RST Legacy ORom”吗?如果是,它被设置为Disabled。我把它设置为 主板手册和技嘉/英特尔的网站说要设置它。 在彻底安装Windows 10和Optane软件之后,Optane驱动器确实可以正常工作。 在我更新主板BIOS后,Optane驱动器停止工作。 我的主板BIOS仍然设置了如何更新它之前直到今天我还没有更改任何设置。 以下是我的BIOS如何,现在仍然是,设置: Bios菜单: CSM支持:已禁用 外围设备菜单: SATA控制器:已启用 SATA模式选择:采用英特尔Optane系统加速的英特尔RST Premium 使用RST Legacy OROM:已禁用 RST控制PCIe存储设备:自动 端口21上的PCIe存储开发:受RST控制 积极的LPM支持:已启用 据我所知,这些是配置Optane所需的唯一设置。 虽然,我刚刚注意到Bios中的以下选项,主板Bios / Peripherals / SATA磁盘信息/ OPTANE磁盘信息。 我不记得以前见过这本手册没有涉及,但它可能对您有用或有用吗? 磁盘操作: 重置为非optane? 港口:1 型号:INTEL MEMPEK1W032GA 序列号:PHBT7 *********** 尺寸:27.2GB 状态:离线 控制器类型:NVMe 控制器接口:PCIe 如果我将所有BIOS的Optand设置恢复为默认值(CSM:启用/ SATA模式:AHCI等)。我的电脑将无法启动,它只会返回BIOS设置。 我不明白这一点.. optane驱动器已设置并配置为在BIOS更新之前与我的硬盘一起运行,并且它工作正常。 BIOS更新后,Windows说它没有安装,但是我的硬盘仍在运行,就像Windows丢失Optane硬盘之前一样? 以上来自于谷歌翻译 以下为原文 Hello and thank you again for replying. I'd like to ask, when you said my BIOS mode is set in “Legacy mode". Do you mean the option in Bios "Use RST Legacy ORom"? If so, it is set to Disabled. I set it up how the Motherboards manual and Gigabyte's/Intel's website say to set it up. After a clean install of Windows 10 and Optane software, the Optane drive did work perfectly. It was after I updated the Motherboards BIOS that the the Optane drive stopped working. My Motherboards BIOS is still set up how it was before I updated it and up until today I haven't changed any settings. Below is how my BIOS was and still is, set up: Bios Menu: CSM Support: Disabled Peripherals Menu: SATA Controller(s): Enabled SATA Mode Selection: Intel RST Premium With Intel Optane System Acceleration Use RST Legacy OROM: Disabled RST Control PCIe Storage Devices: Auto PCIe Storage Dev On Port 21: RST Controlled Aggressive LPM Support: Enabled As far as I am aware, these are the only settings needed to configure Optane. Athough, I have just noticed the following option in the Bios, in the Motherboards Bios/Peripherals/SATA Disk Information/OPTANE Disk Info. Which I don't remember seeing before and it isn't covered in the manual, but it may be relevant or useful to you? Disk Actions: Reset to non-optane? Port: 1 Model Number: INTEL MEMPEK1W032GA Serial Number: PHBT7*********** Size: 27.2GB Status: Offline Controller Type: NVMe Controller Interface: PCIe If I change all the BIOS's Optand settings back to default (CSM: Enabled / SATA Mode: AHCI etc..) My PC won't boot, it just goes back into BIOS Settings. I don't understanding this.. the optane drive was set up and configured to run with my HDD before the BIOS Update, and it worked fine. After the BIOS update, Windows says it's not installed, but my HDD is still working as it was before Windows lost the Optane drive? |
Bowen_ 发表于 2018-10-23 19:02 Hello Hipster1966,感谢您的回复和所提供的信息。请注意,在固件更新/ BIOS更新后,BIOS上的设置将更改为默认值,建议将BIOS恢复为出厂默认设置并设置优先设置 更多的时间来避免问题。当谈到Optane总是建议在任何主要硬件/软件更改之前禁用Optane并在过程完成后激活加速。在这种情况下,似乎Optane被BIOS识别 如上所述,您可以选择停用Optane,如下所示:磁盘操作:重置为非操作如果此选项可供您运行,我们建议您使用BIOS选项停用Optane并返回 到您的操作系统并尝试再次加速您的系统。请告诉我们结果。最好的问候,JoshB.Intel®客户支持威廉希尔官方网站 人员与英特尔公司的合同 以上来自于谷歌翻译 以下为原文 Hello Hipster1966, Thank you for your reply and the information provided. Please take into consideration that after a firmware update/BIOS update the setting on the BIOS change back to defaults and is recommended to return your BIOS to the factory default and setup your preferred setting one more time to avoid issues. When it comes to Optane is always recommended to disable Optane before any major hardware/software change and to activate the acceleration after the process is completed. In this case, it seems that the Optane is being recognized by the BIOS and is giving you the option to deactivate the Optane as you mentioned is showing you the following: Disk Actions: Reset to non-optane If this option is available for you to run it we recommend you to deactivate the Optane using your BIOS option and get back to your OS and to try to accelerate your system one more time. Please let us know the results. Best regards, Josh B. Intel® Customer Support Technician Under Contract to Intel Corporation |
jerry1978 发表于 2018-10-23 19:11 您好,再次感谢您的帮助。 我很高兴地告诉你,我的optane驱动器现在再次运行。 我在Bios中使用了“Reset to non-optane”设置,在启动到windows后,我运行了optane内存工具。 它检测并配置了驱动器,重新启动了电脑并且现在运行正常,最好的部分是我没有必要重新安装Windows了! 因此,我不能非常感谢你对此的帮助,optane是我以前从未使用过的东西,我对这个问题的答案毫无头绪! 以上来自于谷歌翻译 以下为原文 Hello again, thank you for all your help. I am pleased to tell you that my optane drive is now working again. i used the "Reset to non-optane" setting in Bios and after booting into windows, I ran the optane memory tool. It detected and configured the drive, restarted the pc and is running perfectly now, and the best part was that I didnt have to re-install windows AGAIN! So I can't thank you enough for your help with this, optane is something I've never used before and I was clueless for the answer to this problem! |
GMT+8, 2025-7-13 14:23 , Processed in 0.616633 second(s), Total 53, Slave 47 queries .
