嗨罗伯特,你能推荐一下吗?
合适的相机最小尺寸,H264压缩由Raspberry Pi3连接和控制? 适用于Raspberry Pi 3 B控制和相机命令的软件? 谢谢 彼得 以上来自于谷歌翻译 以下为原文 Hi Robert, can you please recommend
Peter |
5个回答
@odenplan,
我见过的大多数h264相机都是以u***为基础的。 这是我们通过相机界面连接到Pi的Raspbery Pi相机列表,因此压缩必须在Pi上进行: https://www.digikey.com/products/en/development-boards-kits-programmers/evaluation-boards-expansion-boards-daughter-cards/797?k=Raspberry+Pi+Camera&k=&pkeyword= 覆盆子+ PI +相机及安培; pv1989 = 0&安培; FV = ffe0031d&安培;数量= 0&安培; ColumnSort = 0&安培;页= 1&安培; pageSize的= 25 PINOIR似乎是最有用的: https://www.digikey.com/product-detail/en/raspberry-pi/913-2673/1690-1012-ND/6152811 Doc's在这里:https://projects.raspberrypi.org/en/projects/getting-started-with-picamera 问候, 以上来自于谷歌翻译 以下为原文 @odenplan, Most of the h264 camera’s I’ve seen are u*** based. Here is our list of Raspbery Pi cameras that connect to the Pi over the camera interface, so the compression would have to be done on the Pi: https://www.digikey.com/products/en/development-boards-kits-programmers/evaluation-boards-expansion-boards-daughter-cards/797?k=Raspberry+Pi+Camera&k=&pkeyword=Raspberry+Pi+Camera&pv1989=0&FV=ffe0031d&quantity=0&ColumnSort=0&page=1&pageSize=25 The PINOIR seems to be the most useful: https://www.digikey.com/product-detail/en/raspberry-pi/913-2673/1690-1012-ND/6152811 Doc’s are here: https://projects.raspberrypi.org/en/projects/getting-started-with-picamera Regards, |
嗨,
只是为了让你明白 如果你应该选择这个Zerocam。 它有一条为Pi Zero制造的更细的电缆。 您无法直接将其连接到Pi3B。 问候, 迈克尔 以上来自于谷歌翻译 以下为原文 Hi, Just to make you aware. If you should select this Zerocam. It has a thinner cable made for the Pi Zero. You can’t directly connect it to the Pi3B. Regards, Michael |
刚刚找到了Pi3B的版本
问候, 迈克尔 以上来自于谷歌翻译 以下为原文 Just found a Version for the Pi3B Regards, Michael |
嗨迈克尔
这台相机有H264压缩吗? 谢谢 彼得 以上来自于谷歌翻译 以下为原文 Hi Michael Does this camera have H264 compression? Thank you Peter |
@odenplan no,该相机使用BCM2835的CSI总线,它将原始像素从相机传输到Raspberry Pi。
H264仍然需要在Pi上完成。 问候, 以上来自于谷歌翻译 以下为原文 @odenplan no, that camera utilizes the BCM2835’s CSI bus, which transfers raw pixels from the camera to the Raspberry Pi. H264 would still have to be done on the Pi. Regards, |
3526 浏览 3 评论
581浏览 1评论
GMT+8, 2025-2-23 20:54 , Processed in 0.532526 second(s), Total 50, Slave 45 queries .
