大家好,
我试图了解具有数据就绪中断的H3LIS331DL传感器的配置。 根据我以前的帖子,我了解配置控制寄存器1后应该给出开启时间。 以下是我用于获取数据就绪中断的序列。 步骤1:为Accel Sensor供电 第2步:将Ctrl_Reg1设置为00111111b(0x3F) 步骤3:当我将ODR配置为1000Hz时,根据数据表提供(1/1000 + 1ms)2 ms的睡眠。 步骤4:使用00000010b(0x02)配置Ctr_Reg3。 步骤5:启用H3LIS中断1和中断2引脚并注册回调API。 第6步:等待数据就绪中断。 在这里,我面临的问题是我看不到数据就绪中断,即数据就绪中断回调功能未触发。 有人遇到过这个问题吗? 谢谢, 湿婆。 #h3lis331#h3lis331dl-configuration#h3lis331dl-data-ready-interrupt 以上来自于谷歌翻译 以下为原文 Hi All, I am trying to understand configuration of H3LIS331DL sensor with Data Ready Interrupt. As per my previous posts, I understood Turn On-Time should be given after Configuring the Control Register 1. Here is the sequence I am using to get Data Ready Interrupt. Step1: Give power to Accel Sensor Step2: Setting Ctrl_Reg1 with 00111111b(0x3F) Step3: As I am configuring ODR as 1000Hz providing sleep of (1/1000+1ms) 2 ms as per data sheet. Step4: Configuring Ctr_Reg3 with 00000010b (0x02). Step 5: Enabling H3LIS Interrupt 1 and Interrupt 2 pins and Registering call back API. Step 6: Waiting for data ready interrupt. Here I am facing problem is I could not see the Data Ready Interrupt, i.e., Data Ready Interrupt call back function is not triggering. Anybody faced this problem ? Thanks, Siva. #h3lis331 #h3lis331dl-configuration #h3lis331dl-data-ready-interrupt |
3个回答
您的传感器配置是正确的,我认为问题出在MCU配置中。
如果您有示波器或逻辑分析仪,则可以检查INT1引脚上的DRDY信号是否可用。 以上来自于谷歌翻译 以下为原文 Your sensor configuration is correct, I suppose the problem is in the MCU configuration. If you have a scope or logic analyzer you can check that the DRDY signal is available on the INT1 pin. |
感谢您输入Miroslav。
这里有一个问题来自上述步骤,其中步骤可以配置Accel传感器的INT1_H3LIS和INT2_H3LIS引脚以启用MCU中断。 以上来自于谷歌翻译 以下为原文 Thanks for your input Miroslav. Here one question will be from above steps in which step suggestible to configure INT1_H3LIS and INT2_H3LIS pins of Accel sensor to enable interrupt from MCU. |
您可以随时配置它,但没有问题。
我个人会在设置ODR之前配置中断(在步骤2之前)。 以上来自于谷歌翻译 以下为原文 You can configure it anytime you want, there is not issue with that. Personally I would configure the interrupts before I set the ODR (before step 2). |
2895 浏览 1 评论
3283 浏览 1 评论
1864 浏览 1 评论
3715 浏览 6 评论
6130 浏览 21 评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
415浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
515浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
340浏览 2评论
使用STM32F407VET6的USB2.0功能,发现ctl后芯片无数据返回,是什么原因可能导致的呢?
248浏览 2评论
用STM32G431开发工程,1.50版本的Package包文件无法输出项目工程
357浏览 2评论
GMT+8, 2025-3-5 12:33 , Processed in 0.940286 second(s), Total 46, Slave 41 queries .
