你好,
我刚买的cy5677 cysmart BLE 4.2子适配器与cy8c4248lqi-bl583。当我进入我的电脑运行cysmart 1.2,它表明不支持的设备。 我点击重置按钮,但它仍然显示不支持的设备。我随后显示在cysmart描述了PSoC的程序员的编程固件,但它显示: 错误:HEX文件不与获取的设备匹配,请检查装置。 我只有在cysmart文件夹的ble_4_2_dongle_cysmart_256k.hex cy5677。我不确定这是否是正确的十六进制文件。如果不正确,我在哪里可以得到正确的HEX文件? CysPrime03.PNG 2.3兆字节 CysPrime01.PNG 53.6 K CyPress 21.7 K 以上来自于百度翻译 以下为原文 Hi, I just bought the CY5677 Cysmart BLE 4.2 SUB Dongle with cy8c4248lqi-bl583. When I plug into my computer and run the Cysmart 1.2, it shows unsupported device. I have clicked reset button but it still shows unsupported device. I then followed the description shown in Cysmart and went to PSoC Programmer to program the firmware but it shows: ERROR: The hex file does not match with the acquired device, please check the device. I only have the BLE_4_2_Dongle_CySmart_256K.hex in Cysmart folder for CY5677. I am not sure if this is the correct hex file. If not correct, where can I get the correct hex file?
6个回答
你好,
基于PSoC的红色GELE的HEX文件将在CyScript新发布的Web上发布 以上来自于百度翻译 以下为原文 Hello, PSoC based Red colored dongle's hex file will get a release on web with CySmart new release |
嗨,安克斯, 请问放行日期是什么时候?谢谢。 以上来自于百度翻译 以下为原文 Hi anks, May I know when is the release date? Thanks. |
这篇文章:CySMAR-蓝牙®LE测试和Debug Tool 提到2018年3月24日更新,但文件看起来要过时得多。不确定是否有任何用途 以上来自于百度翻译 以下为原文 This post: CySmart – Bluetooth® LE Test and Debug Tool Mentions being update March 24, 2018, but the files look to be dated much older. Not sure if that is of any use |
尝试,但仍然相同。 以上来自于百度翻译 以下为原文 Tried but still the same.. |
CYSMARE 1.3支持CY5677 CyStable BLE 4.2 USB加密狗与CY8C4248LQI-BL58D设备现已在CySMAR-蓝牙®LE测试和调试工具上可用。请退房!
以上来自于百度翻译 以下为原文 CySmart 1.3 that supports CY5677 Cysmart BLE 4.2 USB Dongle with CY8C4248LQI-BL583 device is now available on CySmart – Bluetooth® LE Test and Debug Tool. Please check out! |
756个成员聚集在这个小组
加入小组2124 浏览 1 评论
1866 浏览 1 评论
3681 浏览 1 评论
1800 浏览 6 评论
1549 浏览 1 评论
605浏览 2评论
451浏览 2评论
448浏览 2评论
400浏览 2评论
1082浏览 2评论
GMT+8, 2025-1-12 16:42 , Processed in 1.021190 second(s), Total 86, Slave 70 queries .
