有没有办法在Debian上加速Chromium加载和运行时间(9)在BBB上拉伸?
它在Stretch上的运行速度比在相同的BBB H / W上使用Jessie慢得多。 以上来自于谷歌翻译 以下为原文 Is there a way to speed up Chromium load and run time on Debian (9) Stretch on the BBB? It runs considerbly slowere on Stretch than it did using Jessie on the same BBB H/W. |
4个回答
@texasEE可悲的是,Chromium越来越难以在单核设备上运行,例如am335x有限的RAM。
我尝试使用更多的霓虹灯路径重新启用Chromium与默认的debian包,但是即便如此,它在Beagle上也很慢。 在X15这样的双核心部件上它会更快,或者是因为我们让etnaviv为Chromium使用的2d / 3d加速工作。 问候, 以上来自于谷歌翻译 以下为原文 @texasEE Sadly no, Chromium is getting harder to run on single core devices such as the am335x with limited ram. I tried rebuilding Chromium with more neon paths enabled vs the default debian package, however even then it’s slow on the Beagle. On dual core parts such as the X15 it is much faster, or the wandboard as we have etnaviv working for 2d/3d acceleration that Chromium utilizes. Regards, |
有关使用Debian Stretch软件在BBB上运行良好的其他Web浏览器的任何建议吗?
以上来自于谷歌翻译 以下为原文 Any recommendations on other web browsers that would work great on the BBB using the Debian Stretch software? |
Firefox也是可用的,但在诸如am335x之类的单核设备上,它不会很快。
问候, 以上来自于谷歌翻译 以下为原文 Firefox is also available, but on a single core device such as the am335x it’s not going to be fast. Regards, |
为了解决这个问题,我卸载了chrome然后安装了midori。
Midori是一个轻量级的HTML网页浏览器,在BBB上运行得非常好。 必须谨慎行事,因为Midori可能存在不属于Chromium的安全问题。 卸载铬类型: sudo apt-get --purge去除铬(Frees 109MB) 然后安装Midori使用: apt-get install midori(增加80MB) 安装完成后打开一个终端并输入: midori -help-execute 有关Madori命令的列表 以上来自于谷歌翻译 以下为原文 To resolve the issue I uninstalled chromium and then installed midori. Midori is a lightweight HTML web browser that runs very good on the BBB. Caution must be exercised since there may be security issues with Midori that are not in Chromium. To uninstall chromium type: sudo apt-get --purge remove chromium (Frees 109MB) Then install Midori using: apt-get install midori (Adds 80MB) Once installed open a terminal and type: midori -help-execute for list of Madori commands |
3481 浏览 3 评论
523浏览 1评论
GMT+8, 2024-12-29 00:05 , Processed in 0.571030 second(s), Total 51, Slave 46 queries .
