@DigiKey_Internal
你认为这是一个22欧姆的电阻吗? 想知道较小的电阻器上的“黑色”是什么。 它可能只是一个烧伤吗? 关于较小的价值观的任何想法? 以上来自于谷歌翻译 以下为原文 @DigiKey_Internal Do you think this is a 22 ohm resistor? Wondering what the “black” is on the smaller resistor. Could it just be a burn? Any ideas on the value on the smaller one? |
6个回答
黑色绝对是被烧毁的;
烟雾被释放了...... 以上来自于谷歌翻译 以下为原文 Black is definitely burned; the smoke was let out… |
但是,小的1/4瓦电阻似乎是22欧姆
以上来自于谷歌翻译 以下为原文 But yeah the small 1/4 wat resistor appears to be a 22 ohm |
我将选择Brown,Blk,Green,Gold
较小的...... .uffda ......棕色,红色,红色,金色??? 可能是1M欧姆,也许是1.2K欧姆??? 我不确定你的颜色是不是真的很清楚。 T#69696969 黛安鲁德 应用工程威廉希尔官方网站 员 Digi-Key公司 701 Brooks Ave S. Thief River Falls,MN 56701 701 Brooks Ave. 南 Thief River Falls,MN 56701 USA +1 800 344 4539 x 1950 通过请求或接受应用工程服务,即表示您同意以下链接中规定的条款和条件:http://www.digikey.com/en/terms-and-conditions 以上来自于谷歌翻译 以下为原文 I’m going to go with Brown, Blk, Green, Gold on the larger one The smaller one….uffda……Brown, Red, Red, Gold??? So possibly a 1M Ohm and maybe a 1.2K Ohm??? I am not sure tho cuz the coloring is not real clear. T#69696969 Diane Rud Applications Engineering Technician Digi-Key Corporation 701 Brooks Ave S Thief River Falls, MN 56701 701 Brooks Ave. South Thief River Falls, MN 56701 USA +1 800 344 4539 x 1950 By requesting or accepting Applications Engineering services, you agree to the terms and conditions set forth in the following link: http://www.digikey.com/en/terms-and-conditions |
较大的一个棕色,黑色,白色,金色,当点击它两次(真正放大)是明显的。
1千兆欧姆似乎不真实。 idk,我想说这些都是专用电阻器 以上来自于谷歌翻译 以下为原文 Larger one Brown, black, white, gold is evident when click on it twice (really enlarged). 1giga ohm seems unreal. idk, I would say these are specialized resistors |
我会说较大的一个是棕色黑色银色金,给出0.1欧姆5%
较小的看起来像是红色的红色金色,但是领先的0是不可能的。 也许是蓝色或棕色。 这使得它为6.2kOhm 5%或1.2 kOhm 5%。 以上来自于谷歌翻译 以下为原文 I would say the Larger one is Brown Black Silver Gold, which gives a 0.1 Ohm 5% The smaller seems like black red red gold, but a leading 0 is not possible. So maybe Blue or Brown. Which makes it either 6.2kOhm 5% or 1.2 kOhm 5%. |
1 / 4watt小一个在右边
通常你有三个乐队和宽容。 无法看到第一个乐队的颜色是什么...... http://education.rec.ri.cmu.edu/content/electronics/common/resistors/1.html#Read_Resistor 对于第一个被烧掉的乐队,它可以是从黑到白的颜色范围:@O 以上来自于谷歌翻译 以下为原文 1/4watt smaller one on right normally you have three bands and tolerance. Unable to see what the first band color is… http://education.rec.ri.cmu.edu/content/electronics/common/resistors/1.html#Read_Resistor It could be a color range from black to white for the first band which that is burnt away :@O |
3477 浏览 3 评论
521浏览 1评论
GMT+8, 2024-12-24 07:46 , Processed in 0.700502 second(s), Total 88, Slave 72 queries .
