你好@swapnali,
我假设您在询问这些工具是否兼容,以及用户是否可以从一个工具移植到另一个工具。 今天,对于Maker Schematic进入Logic,我们将不得不等待,看看它是否与Mentor兼容。 PADS Maker将能够移植到标准的PADS Layout和xDX Designer中。 如果你试图移动另一种方式会有问题,因为Maker中的限制和Maker中没有的其他功能。 杰里米 以上来自于谷歌翻译 以下为原文 Hello @swapnali, I’ll assume you are asking if these tools are compatible and if a user can port from one to the other. Today for Maker Schematic moving into Logic we will have to wait and see if that is compatible from Mentor. PADS Maker will be able to port into standard PADS Layout and xDX Designer. If you are trying to move the other way that will be problematic because of the limitations in Maker and other functionality that is not in Maker. Jeremy |
你好@swapnali,
感谢您对PADS Maker的关注! 根据Mentor PADS Maker的同事的回复,Maker将无法进入PADS Logic。 我希望能回答你关于这个问题的问题。 如果您有任何我们可以回答的问题,请告诉我们。 杰里米 以上来自于谷歌翻译 以下为原文 Hello @swapnali, Thank you for your interest in PADS Maker! Based on responses from our colleagues at Mentor PADS Maker will not be able to port into PADS Logic. I hope that answers your questions on this subject. Let us know if you have any more question that we can answer. Jeremy |
在Pads maker原理图中,我找不到保存/另存为选项。
请你能帮忙吗? 以上来自于谷歌翻译 以下为原文 In Pads maker schematic, i will not found save /save as options. please can you help for same. |
你好@swapnali
有一个自动保存功能,可以在您工作时定期保存您的工作。 关闭原理图时,它还会自动保存项目。 如果您有任何其他问题,请与我们联系。 罗伯特 以上来自于谷歌翻译 以下为原文 Hello @swapnali There is an automatic save feature that periodically saves your work as you are working. It also automatically saves your project when you close your schematic. Please let me know if you have any further questions. Robert |
你好@swapnali
此外,如果您要复制像保存和重命名这样的项目,您在这里要做的是打开一个项目,在文件选项卡中应该有一个选项可以复制项目。 这将打开一个菜单,允许您重命名甚至将新项目放在不同的目录中。 我希望我们已就此主题回答了您的所有问题,如果没有,请随时向我们提出更多问题。 感谢您对PADS Maker的关注。 杰里米 以上来自于谷歌翻译 以下为原文 Hello @swapnali Also if you are looking to copy a project like save as and rename, what you would do here is open a project and there should be an option in the File tab where you can copy a project. This will bring up a menu that will allow you to rename and even put the new project in a different directory. I hope we have answered all your questions around this topic, if not please feel free to ask us more. Thank you for your interest in PADS Maker. Jeremy |
3580 浏览 3 评论
657浏览 1评论
GMT+8, 2025-4-23 18:14 , Processed in 0.615609 second(s), Total 51, Slave 45 queries .
