你好?
我想创建一个利用CAN网络的设备。 这是我第一次用CAN网络开发。 我想用PSOC5作为主设备。 PSOC5是否适用于自动化设备中的开放式主设备? 你有使用这个的经验吗? 我很感激你的建议。 谢谢您。 以上来自于百度翻译 以下为原文 Hello? I want to create a device that utilizes the CAN network. It is my first time to develop with CAN network. I want to use PSOC5 as master device. Is the PSOC5 suitable for CAN-OPEN master device in an automation device? Do you have experience using this? I would appreciate your advice. Thank you. |
你好,
对不起,我们没有在PoSO5CAN组件上实现CAN-OPEN。 CAN-OPEN是一个包含网络层和以上CAN的库。 PSoC 5具有CAN组件,包括物理链路层和数据链路层。默认情况下它没有CAN-OPEN。 但是用户可以通过它实现这个库。 我们没有任何实施或测试的例子。 然而,用户可以自由地实现对它的测试。 如果你需要澄清,请告诉我。 当做 哈尔沙塔 以上来自于百度翻译 以下为原文 Hi, Sorry but we don't have CAN-OPEN implemented over PSoC5 CAN component. CAN-OPEN is a library that contains Network layer and above over CAN. PSoC 5 has CAN component which includes Physical and Data link layer. It doesn't have CAN-OPEN by default. However user can implement this library over it. We don't have any example implemented or tested. However the user is free to implement the library an test it. Let me know if you need any clarification. Regards Harshada |
756个成员聚集在这个小组
加入小组2124 浏览 1 评论
1866 浏览 1 评论
3682 浏览 1 评论
1800 浏览 6 评论
1549 浏览 1 评论
611浏览 2评论
453浏览 2评论
450浏览 2评论
400浏览 2评论
1084浏览 2评论
GMT+8, 2025-1-13 09:19 , Processed in 0.647540 second(s), Total 44, Slave 39 queries .
