我的英特尔软件说有一个更新:用于英特尔®NUC套件NUC8i7BE的Thunderbolt™总线驱动程序,NUC8i5BE,NUC8i3BEI下载它,并重新检查更新。
说有更新。 一样的。 我点击它然后问我是否愿意 修复,自定义或删除。 只有可以选择的选项是删除。 为什么软件不知道它已被下载? 我重新启动了计算机和同样的问题。 非常困惑。 - 以上来自于谷歌翻译 以下为原文 My intel software says there is an update: Thunderbolt™ Bus Driver for Intel® NUC Kit NUC8i7BE, NUC8i5BE, NUC8i3BE I download it, and recheck for updates. Says there is an update. Same one. I click on it and it asks if I want to repair, customize or delete. Only option that can be selected is delete. Why isn't the software aware it's been downloaded? I've rebooted the computer and same issue. very perplexed. - |
5个回答
这是一个错误。
我也在非NUC系统上看到它。 我们必须让英特尔支持工程师看看这个问题。 另外,我已经报道了这一点。 文件 以上来自于谷歌翻译 以下为原文 This is an error. I am seeing it as well on non-NUC systems. We will have to have the Intel support Engineers look at the problem. Also, I have reported this. Doc |
我有同样的问题&
以为这是我的电脑。 离开更新程序运行两个小时后看看Thunderbolt是否会完成我然后花了一个小时来卸载驱动程序更新程序,卸载Thunderbolt& 重新安装它们,关闭电脑和电脑; 回来。 希望很快就能到达。 以上来自于谷歌翻译 以下为原文 I have the same problem & thought it was my PC. After leaving the updater to run for two hours to see if Thunderbolt would complete I then spent an hour of so uninstalling the driver updater, uninstalling Thunderbolt & reinstalling them again, turning off the PC & back on. Hopefully there's a fix arriving soon. |
ll1589179925 发表于 2018-10-19 14:31 大家好, 感谢您发布此内容。 我已更新此Thunderbolt驱动程序的清单,仅适用于英特尔NUC系统。 此更改应在接下来的几个小时内通过系统。 问候, 路易斯H. 英特尔 以上来自于谷歌翻译 以下为原文 Hi all, Thanks for posting this. I have updated the manifest for this Thunderbolt driver, to be delivered only for Intel NUC systems. This change should roll through the system within the next couple of hours. Regards, Lois H Intel |
只有一个问题,Lois H. 是否可以卸载该更新,因为我觉得我不需要它。 以上来自于谷歌翻译 以下为原文 Just one Question, Lois H Is it ok to uninstall that update as I feel that I don't need it. |
谢谢!!! 刚刚检查过,我的更新顾问看起来都很好看。 欣赏快速响应和修复。 以上来自于谷歌翻译 以下为原文 THANKS!!! Just checked and all looks good on my update advisor. Appreciate the quick response and fix. |
371浏览 0评论
GMT+8, 2024-9-23 07:33 , Processed in 0.735905 second(s), Total 86, Slave 70 queries .
