嗨,我昨天回来看了这个。Microchip现在被列为合作伙伴,你可以下载一个用好奇板设计的代码。它用新编译器编译,但它不是一个和谐项目。-他们已经把所有的工作都变成了一个有用的系统,但是它并不是一个和谐的项目。这是怎么发生的?它现在是一个很大的努力来弄清楚到底发生了什么。
以上来自于百度翻译 以下为原文 Hi, I got back around to looking at this, yesterday. Microchip is now listed as a partner, and you can download code that is designed for using with a curiosity board. It compiles with the new compiler, however its not a hARMony project. :-( They have got all the bits working to make it a useful system however its not been built as a harmony project. How did this happen? Its now a big effort to figure out whats going on. |
7个回答
一旦你通过了和谐的“奇怪”。(这需要一些习惯)它把东西放在一起很快…把这个项目变成另一个项目现在变成了更多的工作。
以上来自于百度翻译 以下为原文 Once you get past the 'oddness' of harmony thigns. ( which does take some getting used to ) its increadibly fast to put stuff together.. Moving this project around to be something else now becomes a LOT LOT more work. |
嗨,为什么它应该是一个和谐的项目?在AWS网站中,它被解释为基于FrReSerto.Fieltos已经出现在很久以前的和声中,并且是一个基于上下文切换的OS。FReRotos也打算移植到任何硬件上,独立于制造商和许可限制。上下文切换是CONCE。不同于合作多任务的状态机,主要是和谐建议。许可限制?如果你把一个有许多和谐的生成和框架代码的项目搬到NXP微控制器,那会在许可规则之内吗?和谐正在努力利用和谐框架外围层,这是为了驱动和应用程序可移植到其他硬件,但是和谐的外围层文件对于TI微控制器是可用的吗?如果是,许可证规定是什么?Microchip也不能使一切和谐。它们实际上运行2个不同的软件工作:微芯片代码配置器独立于,并且不同于和谐。迈西尔
以上来自于百度翻译 以下为原文 Hi, Why should it be a harmony project? In the AWS website, it is explained to be based on FreeRTOS. FreeRTOS have been around from long before Harmony, and is a OS supporting based on context switching. FreeRTOS is also intended to be ported to any hardware, independent of manufacturer and licensing restrictions. Context switching is conceptually different from the Cooperative Multitasking with state machines that is primarily suggested in Harmony. Licensing restrictions? What if you move a project with a lot of Harmony generated and Framework code to a NXP microcontroller, would that be within the licensing rules? Harmony is putting a lot of effort into making use of harmony framework peripheral layer. This is with the intention that drivers and application shall be portable to other hardware, but are harmony peripheral layer files available for TI microcontrollers? and if they were, what would the licensing rules be? Microchip also do not make everything Harmony. They are actually running 2 separate and different software efforts: Microchip Code Configurator is independent of, and different from Harmony. Mysil |
我喜欢PIC和Microchip很多,但是在使用CouthMax用于一个项目之后,就不可能使用和声,而且我在和声阶段早期被烧掉了,勉强地搬走了,我知道PuxMeX是软件问题还是连接问题。有了和谐,我不确定生成的代码是问题还是芯片错误,还是硬件问题。我宁愿从头开始写所有的东西,不惜一切代价避免和谐,我已经被破坏了。我用状态机和东西没有问题,但是他们在早期就搞砸了,现在很难东山再起。我的意思是PLIB是令人敬畏的,作为我的PIC粉丝,当它开始时,我首先跳到了和谐中,被烧了,伤痕累累,伤痕累累一千次,在使用BICGY PIC32 MZ ADC(噩梦)的时候,我别无选择,只能切换到STM32,用于未来的项目。我指的是用来生成错误编译的代码,比如数百万的错误!他们明确表示PLIB是“遗产”。PIC24是如此容易使用,我的意思是与MCC和MLA的PIC24FJ128GB204,它就像一切工作完美无瑕,然后我看PIC32和畏缩使用它当我想到和谐,如果我投资PLIB,那么我知道它最终将过时,我不能使用的设备,我真的真的W蚂蚁使用(PIC32 MXDA,PIC32 MK)与它,所以我被撕裂了。现在我同意和睦好一点,但是我已经开始了,和睦就像前一天,在你找到别人之后,一切都会好起来。现在我使用的是PIC32的原因(产品已经建成),但我已经超过它了。和谐不是你,而是我。好吧,我撒谎,是你!
以上来自于百度翻译 以下为原文 I like PIC's and Microchip a lot but after using CubeMX for a project, it's impossible to use Harmony, plus I was burned early on in the Harmony stages and reluctantly moved away, with CubeMX I know for sure if it's a software problem or a connection problem. With Harmony I'm not sure if the generated code is the problem or a chip errata, or a hardware problem. I prefer to write everything from scratch now, and avoid harmony at all costs, I'm already damaged. I have no problem using state machines and stuff, but they messed up early on and it's hard to make a comeback now. I mean plib was awesome and being the PIC fanboy that I am I jumped headfirst into harmony when it started and got burned and scarred and burned and scarred a thousand times, on top of using the buggy PIC32MZ ADC (a nightmare) I had no choice but to switch to the STM32 for future projects. I mean Harmony used to generate code that compiled with errors, like MILLIONS of errors!! And they made it clear plib is "legacy". PIC24 is so much easier to use I mean with the PIC24FJ128GB204 with MCC and MLA, it's like everything works FLAWLESSLY, then I look at the PIC32 and cringe to use it when I think about Harmony, if I invest in plib, then I know it will eventually be obsoleted and I cant use devices I really really want to used (PIC32MXDA, PIC32MK) with it, so I am torn. Now I agree Harmony is a little better, but I already moved on, Harmony is like the ex that does everything right after you have found someone else. Right now I'm using PIC32 cause of the kids (product build already), but I'm already over it. Harmony it's not you, it's me. Okay I lied it's you! |
和谐和FreeRTOS不是排他性的。和声让你现在可以创建基于FieltOS的项目。
以上来自于百度翻译 以下为原文 harmony and FreeRTOS are not exclusive. Harmony lets you build freetos based projects now. |
有趣的是,FrRetos/Amazon代码显然是以和谐为基础的项目开始的。
以上来自于百度翻译 以下为原文 Whats interesting/ odd, the FreeRTOS/amazon code clearly started its life as a harmony based project, |
好消息是,我已经骗过了那些做过这件事的人,而且效果很好。他给了我一些建议,所以我现在正努力使之有效。
以上来自于百度翻译 以下为原文 The good news is i've locarted someone whos done it, and it works just fine. And hes giving me some pointers so i'm now working towards making it work. |
5342 浏览 9 评论
2085 浏览 8 评论
1989 浏览 10 评论
3265 浏览 3 评论
2302 浏览 5 评论
847浏览 1评论
741浏览 1评论
684浏览 1评论
741浏览 0评论
631浏览 0评论
GMT+8, 2025-2-13 11:28 , Processed in 1.263145 second(s), Total 85, Slave 69 queries .
