嗨,大家好,
有没有人知道43903芯片有内部(片上)温度传感器吗? 如果是的话,我将非常感激任何信息如何取回它的温度值… 以上来自于百度翻译 以下为原文 Hi all, Anybody knows if 43903 chip has internal (on-chip) temperature sensor? If yes, I would be really grateful for any kind of info how to retrieve a temperature value from it... |
您可以使用WL PythTimeScript命令检查模具温度。在这之前确保WLAN在状态和设置WL MPC 0。如果你想使用的API,你可以检查iovar phy_tempsense(位于43xxx_wi-fi /图书馆/测试/ wl_tool / 43909b0 /王/执行/ WLM。C线2616号)。我附上一个示例代码在cyw943907aeval1f平台进行测试,看看是否有帮助。对于IOCTL / iovars的进一步了解,你可以参考如何在cyw43907使用ioctl命令
DIYTAMP.C.ZIP 618字节 以上来自于百度翻译 以下为原文 You can use wl phy_tempsense command to check the die temperature. Before doing that make sure WLAN is in up state and by setting wl mpc 0. If you want to use APIs, you can check the IOVAR phy_tempsense (as located in line no. 2616 of 43xxx_Wi-Fi/libraries/test/wl_tool/43909B0/wl/exe/wlm.c) . I am attaching a sample code here tested with CYW943907AEVAL1F platform, see if that helps. For further understanding of IOCTL/IOVARs, you can refer to How to use IOCTL commands in CYW43907
chm5 发表于 2018-10-18 16:32 谢谢罗伊… 你为我描述的解决方案。 以上来自于百度翻译 以下为原文 Thanks rroy... Solution described by you works for me. |
754个成员聚集在这个小组
加入小组2110 浏览 1 评论
1858 浏览 1 评论
3673 浏览 1 评论
1791 浏览 6 评论
1540 浏览 1 评论
576浏览 2评论
430浏览 2评论
440浏览 2评论
390浏览 2评论
934浏览 2评论
GMT+8, 2024-12-27 16:49 , Processed in 0.995849 second(s), Total 77, Slave 61 queries .
