你好,
我在我的NUC上运行Libreelec用于HTPC但是厌倦了我遇到的无数问题。 因此,我决定将操作系统更改为Windows 10.我将Windows 10媒体创建器下载到USB,并尝试在创建USB记忆棒后更改NUC上的操作系统。 在安装期间,WIndows不喜欢我的分区,所以我删除了所有分区并有一个未分配的块。 Windows然后安装并完成安装。 自动重启后,启动永远不会超过英特尔NUC屏幕上的F2,F7,F10选项。 所以30分钟左右后,我手动重启了NUC。 此时我遇到了POST错误,无法对NUC做任何事情。 如果我的回答是肯定的,那么NUC就会变得没有反应。 如果我回答否,那么NUC将进入NUC屏幕而不是继续。 我最终能够通过移除跳线来进行bios恢复。 bios恢复工作,我有最新的BIOS。 POST错误不再发生。 但是,我仍然无法启动NUC屏幕。 我无法通过F2进入BIOS。 我唯一可以工作的是没有跳线的完整BIOS恢复。 那里有解决方案吗? 我的下一个解决方案是看看我能投入多大程度的NUC。 谢谢, 布赖恩 以上来自于谷歌翻译 以下为原文 Hello, I was running Libreelec for a HTPC on my NUC but grew tired of the myriad of issues I was having. So I decided to change OS to Windows 10. I downloaded Windows 10 media creator to a USB and attempted to change my OS on the NUC after creating the USB stick. During the install WIndows did not like my partitioning, so I deleted all of the partitions and had one unallocated block. Windows then installed and completed the install. Upon auto reboot, the boot never got past the Intel NUC screen with the F2, F7, F10 options on it. So after 30 minutes or so, I manually rebooted the NUC. At this point I ran into the POST error and could not do anything with the NUC. If I answered yes, the NUC would become unresponsive. If I answered no, the NUC would go to the NUC screen and not continue. I was eventually able to do a bios recovery via removing the jumper. The bios recovery worked and I have the latest BIOS. The POST error does not occur any longer. However, I am still unable to boot past the NUC screen. I am not able to get into the BIOS via F2. The only thing I can get to work is a full BIOS recovery without the jumper. Is there any solutions out there? My next solution is to see how far I can throw a NUC. Thanks, Brian |
4个回答
Hellobriandp32,感谢您加入此英特尔社区。英特尔客户服务不再响应英特尔®NUC套件D54250WYK的电话,聊天或电子邮件查询,但您可能需要尝试我们的“已停产产品社区”以获取其他人的建议
社区成员。 您可能还会发现“已停产的产品网站”有助于满足您的要求。已停产产品社区已停产产品网站请注意,其他社区成员可能会提供帮助,因为英特尔不会向社区提供任何帮助。还值得一提的是您可以验证其他 有关此产品停产状态的信息,请访问http://ark.intel.com/>产品状态>“已停产”.Wanner G.Intel客户支持威廉希尔官方网站 人员与英特尔公司签订合同 以上来自于谷歌翻译 以下为原文 Hello briandp32, Thank you for joining this Intel Community. Intel Customer Service no longer responds to telephone, chat, or e-mail inquiries for Intel® NUC Kit D54250WYK, but you may want to try our "Discontinued Products Community" to get recommendations from fellow community members. You may also find the "Discontinued Products Website" helpful to address your request. Discontinued Products Community Discontinued Products Website Keep in mind that other community members may assist since Intel will not provide any assistance on the Community. It is also worth mentioning that you can verify additional information about this product discontinuance status at http://ark.intel.com/ > Product Status > "Discontinued". Wanner G. Intel Customer Support Technician Under Contract to Intel Corporation |
可能是您的BIOS设置中启用了快速启动。
在这种情况下,您无法看到F2,F7,F10菜单。 您可以启动到电源按钮菜单,在那里您可以禁用快速启动(如果已启用)和/或输入您的BIOS。 要进入电源按钮菜单,请按电源按钮约3秒钟。 您应该尽快释放电源按钮,因为系统将从PC扬声器或耳机发出三声短促的哔声(您需要连接扬声器或耳机至3.5毫米插座),然后停止。 如果听到哔哔声,请松开电源按钮 - NUC将重新启动进入电源按钮菜单。 如果您的NUC无法启动进入电源按钮菜单,请尝试启动配置菜单(您可以在其中获得更多选项)。 要启动此菜单,请移除黄色安全跳线(已移除以进行BIOS恢复)并打开NUC电源。 这次没有插入bios文件的USB棒。 莱昂 以上来自于谷歌翻译 以下为原文 Could be that Fast Boot is enabled in your bios settings. In this case, you can't see the F2,F7,F10 menu. You may boot to Power Button Menu and there you will have possibility to disable the Fast Boot if enabled and/or enter your bios. In order to enter Power Button Menu, press Power Button for about 3 seconds. You should release the Power Button soon as the system will emit three short beeps from the PC speaker or headphones (you need to have connected speaker or headphone to 3.5 mm socket), then stop. If you hear the beeps, release the Power Button - NUC shall reboot into Power Button Menu. If your NUC will not boot into Power Button Menu, try to boot into Configuration Menu (where you have even more options). In order to boot into this menu, remove the yellow security jumper (which you have removed for bios recovery) and power ON your NUC. This time without USB stick with bios file inserted. Leon |
cd340823 发表于 2018-10-18 13:13 莱昂,谢谢你的帮助。 进入电源按钮菜单后,选择F2或F10会导致计算机挂起。 它离开菜单但启动菜单或BIOS永远不会出现。 我重新加载了BIOS,没有任何变化。 我已经更改了显示器,以防它出现图形问题而且没有任何变化。 有什么想法或建议吗? 以上来自于谷歌翻译 以下为原文 Leon, Thanks for the assist. Once inside the power button menu selecting F2 or F10 causes the computer to hang. It leaves the menu but the boot menu or bios never come up. I have reloaded the BIOS again and no change. I have changed monitors in case it was a graphics issue and no change. Any thoughts or suggestions? |
尝试以最低硬件配置启动计算机。 删除SSD和HDD。 只保留一个SODIMM。 您可以单独尝试每个SODIMM - 首先安装在底部插槽中,然后安装在上部插槽中。 莱昂 以上来自于谷歌翻译 以下为原文 Try to boot your computer in minimum hardware configuration. Remove SSD and HDD. Leave only one SODIMM installed. You may try each SODIMM separately - first installed in the bottom slot and then in the upper slot. Leon |
GMT+8, 2025-4-25 21:56 , Processed in 0.606384 second(s), Total 51, Slave 45 queries .
