扫一扫,分享给好友
嗨,我有一个太阳能逆变器与CyPress USB到串行控制器VID 0665 PID 5161。我试着用Linux来使用这个串口。Windows系统发现串行控制器LAS是一个输入设备(HID)。我试图手动安装潜水员但没有改变。我在论坛上看到,要修改控制器,我必须使用CyPress系列配置工具,但是当我打开实用程序时,显然它找不到任何控制器,因为驱动程序不能安装,Windows总是把控制器看作输入设备。如何将这个“输入设备”转换成一个简单的串口COM端口?谢谢!
以上来自于百度翻译 以下为原文 Hi, i've a solar inverter with Cypress USB to Serial controller VID 0665 PID 5161. I'm trying to using this serial port with Linux. Windows system found the serial controller las an input device (HID). I tried to install the diver manually but did not change. I read on the forum that to modify the controller I had to use CypressSerialConfigurationUtility but when i open the utility obviously it does not find any controllers because the drivers can not be installed and windows keeps seeing the controller as an input device. How can I convert this "input device" into a simple serial COM port? Thanks ! |
3个回答
你好,
请右键单击该设备,卸载驱动程序,然后再更新新设备。 当做, - Madhu Sudhan 以上来自于百度翻译 以下为原文 Hi, Please right click the device, uninstall the driver, before updating a new one. Regards, - Madhu Sudhan |
嗨,谢谢你的回复。我已经尝试卸载HID输入设备,并使用您的.INF文件手动安装驱动程序,但Windows一直说驱动程序不正确。 以上来自于百度翻译 以下为原文 Hi, thanks for the reply. I've already tried to uninstall the hid input device and manually install the driver using your .inf file but windows keeps saying that the driver is not correct. |
zhaophqin 发表于 2018-10-17 08:49 嗨,洛尔, 正如我之前说过的,柏树的VID是0x04B4。此外,USB串行产品将不作为HID设备枚举。 无论您配置SCB0和SCB1,都不会看到USB串行枚举为HID设备。 因为我们设置 0x00,/*设备类*// 0x00,/*设备子类*// 0x00,/*设备协议*/ 在固件,这并不意味着一个HID设备。此外,我们不向客户发布固件的源代码。 基于以上原因,我怀疑你一定是做错了什么。 以上来自于百度翻译 以下为原文 Hi lol lol, As I said before, Cypress's VID is 0x04B4. In addition, the USB-serial product will not enumerate as a HID device. You will not see USB-serial enumerating as HID device no matter what you configure SCB0 and SCB1. Because we set 0x00, /* Device class */ 0x00, /* Device sub-class */ 0x00, /* Device protocol */ in the firmware which doesn't mean a HID device. In addition, we don't release the source code of firmware to customer. Based on the reasons above, I suspect you must make something wrong. |
741个成员聚集在这个小组
加入小组2002 浏览 1 评论
1761 浏览 1 评论
3545 浏览 1 评论
1696 浏览 6 评论
1466 浏览 1 评论
273浏览 2评论
170浏览 2评论
355浏览 2评论
299浏览 2评论
487浏览 2评论
GMT+8, 2024-9-20 16:44 , Processed in 0.854004 second(s), Total 79, Slave 63 queries .
