如何才能在英特尔CPU第8代的主板上运行Windows Vista
以上来自于谷歌翻译 以下为原文 how can i make it possible to run Windows Vista on a motherboard with Intel CPU 8th generation |
3个回答
不支持安装。
并且,没有司机。 但是,您可以在Windows 10 Pro中打开Hyper-V,将Vista安装为虚拟机,并且您将不会遇到驱动程序问题。 我在Hyper-V中将Windows 7作为VM运行。 这是一个如何设置它的教程。 Windows 10帮助论坛 我在同一台机器上也有XP作为VM。 现在,当您运行Vista VM时,您将无法获得音频。 但是,您可以远程桌面访问Vista VM并获得所需的所有音频。 好的,我要问 - Vista? 为什么? 文件 以上来自于谷歌翻译 以下为原文 Not supported as an install. And, there are no drivers. However, you can turn on Hyper-V in Windows 10 Pro, install Vista as a virtual machine, and you will have no driver problems. I am running Windows 7 as a VM in Hyper-V. Here is a tutorial on how to set it up. Windows 10 Help Forums I also have XP as a VM on the same machine. Now, when you run the Vista VM, you will not have audio. However, you can Remote Desktop to the Vista VM and have all the audio you need. Ok, I have to ask - Vista? Why? Doc |
mapleasdf 发表于 2018-10-17 12:23 这很明显一旦你拥有它,你永远不会想要Elsevier 它美观,完整,安全,与XP一样合乎逻辑 这是最好的歌,没有比这更好的了 Ik使用的每个系统从95到10 甚至Linux mint 18和Macos 9.0 相信我 VISTA永远 以上来自于谷歌翻译 以下为原文 That's very obvious Once you have it, you never want something Elsevier It is beautiful, complete, safe and as logical as XP It is the best song none is better Ik worked with Every system from 95 to 10 Even Linux mint 18 and Macos 9.0 Believe me VISTA forever |
好吧,但是,在业界,WIndows 7被广泛认为是Vista SP3。 文件 以上来自于谷歌翻译 以下为原文 Ok, but, in the industry, WIndows 7 was widely considered to be Vista SP3. Doc |
504浏览 0评论
GMT+8, 2024-12-10 22:35 , Processed in 0.786808 second(s), Total 82, Slave 66 queries .
