安装较旧的RST v 12.9.0.1001&
它没有显示raid 1 drive& 状态。 什么是华硕Z87主板上的I7-4770处理器的最新RST版本? 操作系统是W10 pro 64bt。 以上来自于谷歌翻译 以下为原文 Have older RST v 12.9.0.1001 installed & it doesn't show the raid 1 drive & status. What is most recent RST version for an I7-4770 processor on an Asus Z87 motherboard? OS is W10 pro 64bt. |
6个回答
beachbum2:我们会尽力提供您所需的信息。
作为第一个建议,在进行任何更改之前,请备份存储在PC上的所有重要信息。 我们建议安装由电路板制造商提供的英特尔®RST版本,在本例中为华硕,因为它们将为您的平台提供正确的版本。我查找了您的电路板型号,并且华硕Z87有不同的结果 主板,如果你提供它的具体型号,我们总是可以尝试寻找与之兼容的英特尔®RST版本:https://www.asus.com/search/results.aspx?SearchKey =华硕% 20Z87 由于您使用的是Windows®10,并且主板可与英特尔®Z87芯片组配合使用,因此我们始终可以尝试安装英特尔®通用RST版本14.8.0.1042:https://downloadcenter.intel.com/download/25165/Intel-Rapid - 存储 - 威廉希尔官方网站 - 英特尔RST-用户界面和驱动程序?产品= 55005 此致,Alberto R. 英特尔客户支持威廉希尔官方网站 人员与英特尔公司签订合同 以上来自于谷歌翻译 以下为原文 beachbum2: We will do our best to provide the information you are looking for. As a first suggestion, before doing any changes, please back up any important information stored on the PC. We recommend to install the Intel® RST version provided by the manufacturer of the board, in this case ASUS, since they will provide the proper version for your platform. I looked for the model of your board and there are different results for the Asus Z87 motherboard, if you provide the specific model of it, we can always try to look for the Intel® RST version that will be compatible with it: https://www.asus.com/search/results.aspx?SearchKey=Asus%20Z87 Since you are using Windows® 10 and the motherboard works with Intel® Z87 Chipset, we can always try to install the Intel® generic RST version 14.8.0.1042: https://downloadcenter.intel.com/download/25165/Intel-Rapid-Storage-Technology-Intel-RST-User-Interface-and-Driver?product=55005 Regards, Alberto R. Intel Customer Support Technician Under Contract to Intel Corporation |
jerry1978 发表于 2018-10-17 19:28 主板型号是华硕Z87-WS。 哪个版本的RST兼容? 以上来自于谷歌翻译 以下为原文 Motherboard model is Asus Z87-WS. Which version of RST is compatible? |
当前RST是版本14.0.0.1143。 Raid 1驱动器虽然在Windows和BIOS中处于活动状态并且不起作用但不会显示。 如何在RST中显示和管理raid 1驱动器? 以上来自于谷歌翻译 以下为原文 Current RST is version 14.0.0.1143. Raid 1 drive does not display although active and functioning in windows and bios. How to get raid 1 drive to display and managed in RST? |
jerry1978 发表于 2018-10-17 20:02 beachbum2:非常感谢您提供这些信息。根据ASUS的网站,该主板与Windows®10不兼容,这就是为什么如果英特尔®RST存在某些问题,他们会有所期待,因为该应用程序是 与您的平台不兼容。在以下链接中,您将能够确认该信息:https://www.asus.com/us/Motherboards/Z87WS/HelpDesk_Download/Regards,Alberto R.Intel与英特尔签订合同的客户支持威廉希尔官方网站 人员 公司 以上来自于谷歌翻译 以下为原文 beachbum2: Thank you very much for providing that information. According to ASUS's web site the board is not compatible with Windows® 10, that is why if there are some kind of problems with the Intel® RST they will be expected, since the application is not compatible with your platform. On the following link you will be able to confirm that information: https://www.asus.com/us/Motherboards/Z87WS/HelpDesk_Download/ Regards, Alberto R. Intel Customer Support Technician Under Contract to Intel Corporation |
mapleasd 发表于 2018-10-17 20:14 完全不同意! 该板成功通过了Windows 10兼容性测试,并且自win10安装以来一直正常运行(超过2年),除了您的RST应用程序之外没有任何兼容性问题。 很好的尝试转移到其他责任 - 但它根本不是真的! 以上来自于谷歌翻译 以下为原文 Disagree completely! The board successfully passed windows 10 compatibility test and has been performing correctly (for over 2 yrs) since win10 install without any compatibility issues except for your RST application. Nice try to deflect to other responsibility - but it's simply not true! |
mapleasd 发表于 2018-10-17 20:28 beachbum2:非常感谢您的反馈。 是的,您始终可以安装Windows®10,但是您可以在之前提供的链接中确认,当我们查找该操作系统的驱动程序时,它不会显示为支持。 在这种情况下,我们建议直接与华硕联系,以便他们确认Windows®10是否与主板兼容以及在何处获取驱动程序,包括正确版本的英特尔®RST: 官方支持| 华硕全球 此致,Alberto R. 英特尔客户支持威廉希尔官方网站 人员与英特尔公司签订合同 以上来自于谷歌翻译 以下为原文 beachbum2: Thank you very much for your feedback. Yes, you can always install Windows® 10, but as you can confirm in the link provided previously, when we looked for drivers for that operating system, it is not showing as supported. In this case then, what we recommend is to get in contact directly with Asus so they can confirm if Windows® 10 is compatible with the board and where to get the drivers for it, including the proper version of Intel® RST: Official Support | ASUS Global Regards, Alberto R. Intel Customer Support Technician Under Contract to Intel Corporation |
370浏览 0评论
GMT+8, 2024-9-21 08:14 , Processed in 0.593005 second(s), Total 55, Slave 49 queries .
