我知道3.5毫米连接器的推荐扭矩是8磅英寸,这就是我使用的。
我有几个扭矩扳手 - 一个来自85052B校准套件,另一个是85033E校准套件。 虽然最近都没有校准,但它们都非常相似,所以我认为两者都没有相当大。 我目前正在剥离一个8515A 26.5 GHz S参数测试装置,目的是为8753制作一个频率扩展器.8515A上的所有内部连接都是3.5 mm。 我发现用8磅英寸的扭矩扳手无法拆除任何这些连接器。 在连接器上有任何移动之前,扭矩扳手会开始弯曲。 惠普似乎收紧了超过8磅英寸。 我注意到我最近在8720D VNA中取消了一些2.4毫米连接器。 我想知道惠普是否有任何关于内部连接的规则,连接器预计仅制造一次,使用的扭矩远高于8磅英寸。 戴夫 以上来自于谷歌翻译 以下为原文 I know the recommended torque for 3.5 mm connectors is 8 lb inch, and that is what I use. I have a couple of torque wrenches - one from an 85052B cal kit and the other an 85033E cal kit. Although neither are recently calibrated, they are both pretty much similar, so I don't think either are considerably out. I am currently stripping down an 8515A 26.5 GHz S-parameter test set, with a view to making a frequency extender for an 8753. All internal connections on the 8515A are 3.5 mm. I find there's no possible way any of these connectors could be removed with an 8 lb inch torque wrench. The torque wrench would start to bend well before there was any movement on the connectors. HP seem to be tightened them considerably more than 8 lb inch. I noticed the same with some 2.4 mm connectors that I recently undone in an 8720D VNA. I'm wondering if HP had any rule that for internal connections, where connectors would expected to be made only once, that a torque well above 8 lb inch was used. Dave |
事实上,我没有确切的数字,但我认为它是10或12英寸 - 磅。
用于校准标准的扭矩扳手设计用于在施加和移除它们时将它们扭转到精确但不太高的值。 扭矩实际上压缩了外导体(虽然它是固体金属)很小的量,因此要保持开启和短路的非常恒定的相位,并且需要精确的扭矩。 但是,它对于仪器内部可靠的长期连接来说太低了。 此外,在很长一段时间内,连接器将“冷焊”,有时它们需要非常大的扭矩来松脱。 以上来自于谷歌翻译 以下为原文 Indeed, I don't have the exact number but I think it is either 10 or 12 inch-pounds. The torque wrench for calibration standards is designed to torque them to an exact, but not too high, value, as they are applied and removed. The torque actually compresses the outer conductor (though it is solid metal) a tiny amount, so to keep very constant phase for opens and shorts, and exact torque is needed. But, it is too low for reliable long term connections inside the instruments. Further, over a long time, connectors will "cold-weld" and sometimes they take very large torques to break loose. |
脑洞大赛9 发表于 2018-10-16 17:41 > {quote:title = Dr_joel写道:} {quote}>确实,我没有确切的数字,但我认为它是10或12英寸磅。 用于校准标准的扭矩扳手设计用于在施加和移除它们时将它们扭转到精确但不太高的值。 扭矩实际上压缩外导体(虽然它是实心金属)很小,因此要保持开启和短路的非常恒定的相位,并且需要精确的扭矩。 但是,它对于仪器内部可靠的长期连接来说太低了。 此外,在很长一段时间内,连接器将“冷焊”,有时它们需要非常大的扭矩来松脱。 干杯乔尔。 这解释了我所观察到的,虽然我甚至没有考虑过冷焊。 如果你碰巧发现它是10英寸还是12磅英寸的一次性连接,我很想知道。 我只看到过任何地方提到的8磅英寸的数字,但更确切地说,如果只进行一次连接,使用额外的扭矩来帮助移动的设备的长期可靠性将是有益的。 周围。 DaveEdited:drkirkby于2015年11月1日下午8:32 以上来自于谷歌翻译 以下为原文 > {quote:title=Dr_joel wrote:}{quote} > Indeed, I don't have the exact number but I think it is either 10 or 12 inch-pounds. The torque wrench for calibration standards is designed to torque them to an exact, but not too high, value, as they are applied and removed. The torque actually compresses the outer conductor (though it is solid metal) a tiny amount, so to keep very constant phase for opens and shorts, and exact torque is needed. But, it is too low for reliable long term connections inside the instruments. Further, over a long time, connectors will "cold-weld" and sometimes they take very large torques to break loose. Cheers Joel. That explains what I'd observed, although I not even considered cold welding. If you do happen to discover whether its 10 or 12 lb inch for one-off connections, I would be interested to know. I've only ever seen the figure of 8 lb inch mentioned anywhere, but it does make more sense that if a connection is only to be done once, it would be beneficial to use extra torque to aid long term reliability of equipment that gets moved around. Dave Edited by: drkirkby on Nov 1, 2015 8:32 PM |
1596 浏览 0 评论
2550 浏览 1 评论
2423 浏览 1 评论
2257 浏览 5 评论
3189 浏览 3 评论
1002浏览 0评论
1596浏览 0评论
GMT+8, 2025-7-3 13:31 , Processed in 1.361302 second(s), Total 77, Slave 61 queries .
