使用fw 10.20。
在做SMC和DIQ cals之后,我想出了增益和端口功率方面的一些错误。 附加的.csa和.png文件是我正在尝试测量的子集,手动完成设置,因此我的程序没有进入图片。 如果您查看png文件,则使用一个CalAll完成窗口1和窗口3,使用标准SMC校准向导完成窗口2。 我在校准和测量期间将端口功率设置为-10dBm,我有大约15 dB的电缆损耗。 两次SMC测量显示IPwr约为-7.2dBm,增益约为-16dB。 我用功率计手动测量了增益,这似乎与-16dB一致,并且功率输出也同意。 因此,测得的功率输出比设定的端口功率高约2.7 dB。 对于DIQ测量,IPwrF1测量与设定端口功率一致,但测量功率约为-7.3dBm,与SMC测量功率相同。 DIQ增益比SMC增益高2.9dB,与SMC功率测量的误差大致相同。 在我移动测试设置之前,这一切都在一周前工作。 我不知道是否有一些晦涩难懂的设置被改变了,但我找不到它。 谢谢你提供的所有帮助。 SMC_SMC_DIQ Source Power Cal Test.png69.9 KB 以上来自于谷歌翻译 以下为原文 Using fw 10.20. I'm coming up with some errors in gain and port power after doing SMC and DIQ cals. The attached .csa and .png files are subsets of what I'm trying to measure, with the settings done manually so my program doesn't come into the picture. If you look at the png file, windows 1 and 3 were done using one CalAll, window 2 was done using a standard SMC cal wizard. I set port power to -10dBm during the cal and for the measurement, and I have about 15 dB cable loss. The two SMC measurements show IPwr at about -7.2dBm, and gain at about -16dB. I've measured the gain manually with a power meter, and that seems to agree with the -16dB, and the power out also agrees. So the measured power out is about 2.7 dB higher than the set port power. For the DIQ measurement, the IPwrF1 measurement agrees with the set port power, but the measured power is about -7.3dBm, the same as the SMC measured powers. And the DIQ gain is 2.9dB higher than the SMC gains, about the same error as the SMC power measurements. This all worked about a week ago, before I moved the test setup. I don't know if there was some obscure setting that was changed, but I haven't been able to find it. Thanks for any help you can give. 附件
没关系。
事实证明,糟糕的ECAL给出了非常混乱的结果。 不便之处,敬请原谅。 以上来自于谷歌翻译 以下为原文 Never mind. It turned out a bad ECAL gave very confusing results. Sorry about any inconvenience. |
1327 浏览 0 评论
2394 浏览 1 评论
2213 浏览 1 评论
2084 浏览 5 评论
2971 浏览 3 评论
1223浏览 1评论
781浏览 0评论
1023浏览 0评论
1328浏览 0评论
GMT+8, 2025-1-11 18:35 , Processed in 1.293691 second(s), Total 76, Slave 60 queries .
