嘿,所有,我现在把一个Windows批处理文件用于生产环境中,通过IPE命令行(iPECDM.jar)编程设备。我写的设备没有问题,但是每次运行命令时,我最终得到5个日志文件:Log.0Log.1Log.2MPLABxLog.XMLMPLABXLog.xML.LCKIs身体知道是否有一种方法来抑制这些日志?IPECM.HTM文件的自述文件似乎根本没有提到这些日志文件,更不用说如何抑制它们了。这可能是我们的生产机器的一个潜在问题,因为它们将从网络位置运行批处理文件,并且没有对这些批处理文件运行的目录的写权限。我想这会产生一个错误消息,虽然我还没有在一台生产机器上测试过。只要能压制它们就很理想了。如果有人有Em,欣赏任何技巧。
以上来自于百度翻译 以下为原文 Hey all, I'm currently putting together a windows batch file for use in a production environment to program a device via the ipe command line (ipecmd.jar). I'm writing the device no problem, but every time I run the command I end up with 5 log files: log.0 log.1 log.2 MPLABXLog.xml MPLABXLog.xml.lck Is anybody aware if there is a way to suppress these logs? The Readme for IPECMD.htm file doesn't seem to mention these log files at all, let alone how to suppress them. This could be a potential issue with our production machines, as they will be running the batch file from a network location, and do not have write permissions for the directory from which these batch files will be run. I would imagine this would throw an error message, although I haven't tested this on one of the production machines yet. It would be ideal to just be able to suppress them. Appreciate any tips/tricks if anyone out there has 'em. |
3个回答
MPLAB IPE用户的引导HTTP://WW1.MICCHIP.COM/DeLoSs/En/DeVICEDC/OC02222C.PDFD提供了抑制日志文件的信息。这需要用户使用高级模式登录(设置-GT;高级模式,如用户指南的图2-5所示)。在高级模式下,设置部分给用户控件选择所需的消息日志记录级别(在诊断部分的表中提供的更多信息,用户指南的表2-6)。将日志记录级别设置为OFF会抑制日志文件。
以上来自于百度翻译 以下为原文 MPLAB IPE User's Guide http://ww1.microchip.com/downloads/en/DeviceDoc/50002227C.pdf provides information on suppressing the log files. This requires the user to log in using the Advanced Mode (Settings -> Advanced Mode, as shown in Figure 2-5 of the User's Guide). In Advanced Mode, the Settings section gives the user control to select the desired message logging level (more information available in the section on Diagnostics, TABLE 2-6 of the User's Guide). Setting the logging level to OFF suppresses the log files. |
请问知道仅烧录qtp文件与hex文件命令怎么写?ipecmd -Sa.num -M -HCS300 -Tppk3 每次都报缺少hex文件,可以之传num文件没有hex吗
5060 浏览 9 评论
1945 浏览 8 评论
1879 浏览 10 评论
3100 浏览 3 评论
2174 浏览 5 评论
613浏览 1评论
484浏览 1评论
343浏览 1评论
515浏览 0评论
422浏览 0评论
GMT+8, 2024-9-20 09:21 , Processed in 1.011831 second(s), Total 49, Slave 44 queries .
