你好!你好吗?
我需要你的帮助。 我对galileo的LINUX SD映像有问题。 当我有micro sd卡时,我的电脑没有阅读intel galileo。 如果Micro SD卡不在Intel Galileo中,我的电脑就能识别它。 以上来自于谷歌翻译 以下为原文 Hello how are you? I need your help. I have problems with the LINUX SD image for galileo. When I have the micro sd card my computer does not read intel galileo. If the micro SD card is not in Intel Galileo my computer recognizes it. |
4个回答
您好luisjrock,感谢您对英特尔Galileo Board的兴趣。请您告诉我们您使用的确切板卡是什么?
伽利略第一代或第二代? 为了在SD卡上刷新图像,您有哪些指示?这是一块新板吗? 你以前遇到过这个问题吗?期待你的回复!最好的问候,伊丽莎 以上来自于谷歌翻译 以下为原文 Hello luisjrock, Thank you for your interest in the Intel Galileo Board. Could you please let us know what is the exact board that you are using? Galileo Gen 1 or Gen 2? What are the instructions that you have followed in order to flash the image on the SD card? Is this a new board? Did you encounter this issue before? Looking forward to your reply! Best regards, Eliza |
jerry1978 发表于 2018-10-16 16:37 你好丽莎。 我正在使用伽利略基因1.我解压缩文件,我将其复制并粘贴在我的micro sd卡上。 我应该用另一种方式吗? 非常感谢您的关注 以上来自于谷歌翻译 以下为原文 Hello lisa. I am using galileo gene 1. I'm unzipping the file, I copy it and paste it on my micro sd card. Should I do it in another way? thank you very much for being attentive |
你好luisjrock,请按照这些说明制作可启动的micro SD: Windows Linux谢谢你,Eliza 以上来自于谷歌翻译 以下为原文 Hello luisjrock, Please follow these instructions in order to make the bootable micro SD: Thank you, Eliza |
你好luisjrock,如果上面提到的解决方案对你有用,请告诉我吗?谢谢你,Eliza 以上来自于谷歌翻译 以下为原文 Hello luisjrock, Could you please let me know if the solution above mentioned was useful to you? Thank you, Eliza |
519浏览 0评论
GMT+8, 2024-12-25 13:33 , Processed in 0.931168 second(s), Total 84, Slave 68 queries .
